So, out of nowhere, my wireless connection doesn't work. I cannot detect any wireless networks, but the adapter is detected in the Network and Sharing Center > Change adapter settings. It's visible there, enabled, with a full green bar (I'm connected to an Ethernet cable now and close to the router), but if I disconnect from the cable, I am no longer connected to the internet, and when I troubleshoot/diagnose, all windows says it "There might be a problem with the driver for the wireless connection adapter."
I have an ASUS N55SL and my adapter is an Intel Centrino Wireless N-100. I have tried everything. Uninstalling and re installing drivers, deleting Intel Wifi folder and registry, restore points won't work, and it's not the AVG network filter problem like some. It just happened out of nowhere. It's actually the second time it did, but unlike last time, it did not fix itself overnight.
I also thought a problem was the ATK package for hotkeys (FN+f2 turned wireless on and off), since when I turned on the computer when this problem started, the wifi was seemingly turned on at first, and I had to press those buttons to turn it on on, but alas, no visible wireless connections and still not connected to them. I have uninstalled the ATK package, and the problem still remains. Same after re-installing it, etc. I have done numerous reboots and tried many so-called "solutions", but none have worked.
A full system re-install is the very last resort option, I have a lot of programs and things I'd need to set up once again. Luckily, last time it fixed itself, but I am not sure about this time, and I really don't want to go through fully re-installing everything once again. If it does do so, though, it would be the biggest relief, but still, I doubt it. Meanwhile, this is the biggest priority. I'm fairly uncomfortable in the only place I can connect the ethernet cable, and I don't want to stay like this for a long time.
This is really stressful, and I ask for your help. If you can figure something out, please, I would truly appreciate it.
Add Sony Vaio Z13 with W7 Pro OS. I spent hours with Sony to troubleshoot the problem and was scheduled to have the hardware replaced but clearly from the tread this will NOT correct the problem. My saving grace is the PC is <6 mths. old and Sony has a pretty good return policy if they are unable to correct the problem. What a shame that I may have to return the PC making sure NOT to buy any PC with Intel's 6235 wireless card. Clearly, Intel is falling short of the mark. The least they could do is acknowledge there is a issue. Their silence is DEAFENING!
I have a Samsung NP550P7C it also comes with an Intel 6235 wireless adapter, I am also unable to detect any wireless connections.
