Wireless
8551 Discussions
Regarding the inability to use AX210 on Win8.1 Professional Edition
Geek
I downloaded Pro/set for win8.1 from Intel website Doesn't work, device manager still shows wireless and bluetooth errors
Labels (2)
Geek
I didn't see the system supported by Ax210, I found it supports Win10 and Win11 after reading the document. Now this problem has been solved, I replaced Ax210 with Ac8260
Steven_Intel
Hello Geek,
I am sorry you are having issues with your Intel® Wi-Fi 6E AX210, I will be glad to help.
Please provide the following information:
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • Are you using the latest wireless drivers available?
  • What errors specifically are you getting in Device Manager? If possible, please take a screen capture showing the error message/code.
Steven G.
Geek
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
Steven_Intel
We are glad to know you found a solution. Since the thread is solved, we will proceed to close it now.
Steven G.
