- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Hi
Where could I find a list over the return codes for the "Wireless_18.2x.xx.zip " drivers?
I need them, but can't find them
Kurt
Lien copié
2 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
b115242,
Is there an specific reason you need this piece of information?
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I would like to find out the result after I run this setup on several hundred PCs.
I found out that the this installation return different results for different PCs.
0 for some models
3010 for one.
I assume that the return codes are the same a MS SCCM expect. If so, I am satisfied.
Is there any reason why this is a secret, and not included with relevant information for the drivers?
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
