I have a laptop, dell inspiron 5567 with an Intel Wireless Dual Band Adapter AC 3165 connected to a network created by an extender (TP LINK TL-WA860RE capable of up to 300 Mbps). I get a download speed of max 12 Mbps and upload speed of about 4.36 Mbps while i have an 50Mbps connection.
From command prompt wireless properties areName : Wi-FiDescription : Intel(R) Dual Band Wireless-AC 3165GUID :Physical address :State : connectedSSID : OTE_N67_extBSSID :Network type : InfrastructureRadio type : 802.11gAuthentication : WPA2-PersonalCipher : TKIPConnection mode : Auto ConnectChannel : 13Receive rate (Mbps): 54Transmit rate (Mbps) : 54Signal : 99%Profile : OTE_N67_ext
On a second laptop, dell inspiron 7520 with an Intel Centrino Wireless N-2230 i get the 30+ Mbps download speed
Name : Wi-Fi Description : Intel(R) Centrino(R) Wireless-N 2230
GUID :
Physical address :
State : connected SSID : OTE_N67_ext
BSSID :
Radio type : 802.11n
Authentication : WPA2-Personal Cipher : CCMP
Channel : 13
Receive rate (Mbps) : 144
Transmit rate (Mbps) : 144
Signal : 99%
Why is there such a difference in speed and how can i fix the speed issue with the first laptop ?
- Tags:
- Dual BandTri Band
Hello Tolis,
We understand you are having problems getting the full download speed available on your laptop using the Intel® Dual Band Wireless-AC 3165.
Thanks to the outputs you have shared, we can see that on this system you have WPA2-Personal with TKIP encryption enabled. This limits your maximum connection rate to only 54 Mbps. The second computer is also using WPA2-Personal, but with CCMP, which allows for the full connection speed.
Connection rate is the speed at which your computer and wireless access point (router) are communicating. This number is always greater than your download speed measurements, as it accounts for the network overhead (encryption, routing information, etc).
Please perform a network reset and let us know if the issue continues:
1. Select the Start button, then select Settings > Network & Internet > Status > Network reset.
2. On the Network reset screen, select Reset now > Yes to confirm.
Wait for your PC to restart and see if that fixes the problem. You will need to connect to your WiFi again, inputting your wireless password.
If the issue continues, please share an Intel® System Support Utility report:
1. Download the latest https://downloadcenter.intel.com/download/25293 Intel® SSU
2. While connected to your WiFi network, run the scan for "everything."
3. Save and name the report.
Carlos A.
Hello Tolis,
Carlos A.
Thanks a lot ! It appears that i had the security and encryption options on the repeater to "auto" which let each device to choose between the 2 encryption protocolls. I set it to "AES" and "WPA2-PSK" and both laptops got CCMP encryption.
Hello Tolis,
We're glad to hear that your issue has been resolved.
If there's anything else we can help you with, please don't hesitate to contact us again.
Carlos A.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
