Wireless
8782 Discussions
Strange roaming behaviour with card AX211 160 MHz
MarcosK
Hello
we have a wireless network with Meraki access points. We see our laptops constantly roaming when users are at their desks, stationary. Roaming occurs even to access points with worse signal.
Meraki access points were verified and we were told that everything was done.
Is there any advice to try at the AX211 card? we are using the recommended settings by Intel.
Channel Width for 5GHzAuto (Access Point determines width)
Roaming AggressivenessMedium
Throughput BoosterDisabled
Transmit PowerHighest
802.11n/ac/ax Wireless Mode802.11ax
Thank you
Marcos
JedG_Intel
Hello MarcosK,
To assist you effectively with the roaming issues that you're reporting, kindly share the information below.
1. Were you able to have wireless connection in a normal/expected performance before?
2. Do you remember if this issue happened after a new OS update or Wireless driver update?
3. Is this a laptop or desktop system?
4. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
5. How many units are affected?
6. Is this issue happening at home, office environment or both?
Best regards
Jed G.
JedG_Intel
Hello MarcosK,
Jed G.
JedG_Intel
Hello MarcosK,
Jed G.
