- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hello
we have a wireless network with Meraki access points. We see our laptops constantly roaming when users are at their desks, stationary. Roaming occurs even to access points with worse signal.
Meraki access points were verified and we were told that everything was done.
Is there any advice to try at the AX211 card? we are using the recommended settings by Intel.
Channel Width for 5GHz | Auto (Access Point determines width) |
Roaming Aggressiveness | Medium |
Throughput Booster | Disabled |
Transmit Power | Highest |
802.11n/ac/ax Wireless Mode | 802.11ax |
Thank you
Marcos
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello MarcosK,
To assist you effectively with the roaming issues that you're reporting, kindly share the information below.
1. Were you able to have wireless connection in a normal/expected performance before?
2. Do you remember if this issue happened after a new OS update or Wireless driver update?
3. Is this a laptop or desktop system?
4. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
5. How many units are affected?
6. Is this issue happening at home, office environment or both?
Best regards
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello MarcosK,
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello MarcosK,
Jed G.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
