Subject: Intel AX200 not connecting via 802.11ax after clean install of Windows 11 24H2
Message:
Hello support team,
I recently performed a clean installation of Windows 11 24H2, and since then my Intel Wi-Fi 6 AX200 160MHz network adapter no longer connects using the 802.11ax (Wi-Fi 6) protocol. It appears limited to 802.11g or ac.
Here’s what I’ve already tried:
- Installed the latest driver version (23.140.05) from Intel’s official website
- Performed a clean driver installation and removed all older versions
- Verified the adapter’s settings to ensure 802.11ax mode is enabled
- Confirmed my router supports Wi-Fi 6 and broadcasts on 5 GHz
- Disabled power-saving settings
- Ensured Windows Update is not reverting the driver version
Despite these steps, the system does not seem to recognize 802.11ax capability. I would appreciate confirmation if this is a known compatibility issue with Windows 11 24H2 or a bug, and whether a fix is planned.
Thank you in advance for your assistance.
Hello Walterio,
To properly address your concern, please share the information below.
1. Is this a laptop or desktop system?
2. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
3. Is this issue happening at home, office environment or both?
4. Do other systems capable of connecting to the 802.11ax network?
Additionally, to have a better understanding of your system configuration and components please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
Hello Walterio,
Jed G.
Hello Walterio,
Jed G.
