Wireless
9047 Discussions
Treiberprobleme
Markus1966
Hallo,
nach dem aktuellen Win 11 24H2 update und dem Update von Intel Wifi 6EAx210 Version 23.120.0.3 gibt es immer wieder Internetunterbrechungen oder es wird nicht mit der Fritzbox 6600 Cable VF verbunden.
Was kann ich tun?
JedG_Intel
Hello Markus1966
Thank you for posting on Intel Community Forums.
Bitte beachten Sie, dass ich Sie nur auf Englisch unterstützen kann. Ich habe ein Web-Übersetzungstool verwendet, um diese Antwort zu übersetzen, daher kann es zu einer ungenauen Übersetzung kommen.
It appears that you are experiencing connection issues following recent updates to your system. To assist you effectively, please provide the following information:
1. What was the last known previous driver version?
2. What made you do the update? Are you having any issues with the previous driver?
3. Have you tried rolling back to the known working OS version and driver version?
4. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
Please also generate SSU report if possible for me to check your system components and configuration.
I look forward for your response.
Jed G.
Markus1966
Hello
thanks for the reply.
The problem is solved.
It was due to an old driver for the repeater.
The problem has now been solved.
Thank you again and best regards.
JedG_Intel
Hi Markus1966,
Thank you for the update and I'm glad to hear that you were able to find the root cause of the issue. Since the issue is resolved, I will now close this inquiry. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
