My Device is an HP Sceptre X360 2-in-1 Laptop 16-f2013dx(74R52AV) of your Intel EVO Series.
Prod(#7HOZ9UA#ABA) and Serial #CND31150LC.
2/. It comes with a WiFi 6E AX211 TriBand +BT 5.3, M.2 (1216?, CVNio2 interface) which I want to Upgrade to a Wifi7 module.
Win.11 Pro. 64 (24H2) is the environment.
My question is since M.2 1216 modules enable platform design optimization with the use of an Intel CNVio interface between CNVi and the Intel Wifi 6AX211 module, providing savings on M/B space, BOM and PCIe port, plus allowing for flexible M/B routing up to 10". would your Terminology "CRF" Companion RF Module, in M.2 refer to which of the Models below in your Product line below that matches my particular card above.
Models. AX211NGW (M.2 2230)
AX211D2W (M.2 1216)
AX211D2WL (M.2 1216, LTE Coex), which
If so, which Intel card? BE201NGW or BE200NGW,
and which size? M.2 2230 or M.2 1216?
I would appreciate your reasoned help
Hello FRANCIS87,
I understand that you would like to upgrade the wireless card on your HP Spectre X360 and you'd like to know which wireless card would be the best and compatible. Please be informed that Installation or use of Intel® Wireless Adapters is subject to country-specific legal regulations. An Intel® Wireless Adapter installed in a system that is being sold on the market doesn't necessarily mean that same wireless adapter can be used or installed in any other systems.
Before you install/change the Intel® Wireless Adapter in a system, you must contact the system manufacturer to determine if the Intel® Wireless Adapters you plan to install is approved for use in your system and country. You are required to follow the manufacturer's post-approval requirements.
You can check the complete information on this article: Regulatory Information Regarding Wireless Hardware Installation or Upgrade
If you have any questions or concerns, please let me know.
Jed G.
Hello FRANCIS87,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
Hello FRANCIS87,
Jed G.
