Wireless
8513 Discussions
Ubuntu 20.04 LTS driver Intel Wi-Fi 6E AX210 160MHz
mailsanchu
I have Wi-Fi 6 AX210 160MHz card on ubuntu 20 04, and I am unable to scan the WIFI 6E AP But I am not able to connect to it. How can I solve this? Any advise
uname -a gives me the following output 5.15.0-69-generic #76~20.04.1-Ubuntu SMP Mon Mar 20 15:54:19 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Alberto_R_Intel
mailsanchu, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is this a new computer?
Were you able to scan and connect to the 6E AP before on this specific machine?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
The wireless card, did you purchase it separately or did it come installed on the computer?
https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html?
Albert R.
mailsanchu
What is the model of the motherboard? DELL
If this is a laptop, what is the model of it? Precision-7760
Is this a new computer? 6 months old
Were you able to scan and connect to the 6E AP before on this specific machine? Nope
If yes, when did the issue start?N/A
Did you make any recent hardware/software changes that might cause this issue? No
The wireless card, did you purchase it separately or did it come installed on the computer? Installed with computer
Does the problem happen at home or in the work environment? ALL Environements
Report attached
Alberto_R_Intel
mailsanchu, Thank you very much for providing that information and the SSU report.
For this scenario, it is important to mention that all the drivers that we have available on our official website were tested and validated for Windows* as Operating System:
https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html?wapkw=ax210
Additionally, we always recommend to install the wireless driver provided by the manufacturer of the computer, since that driver was heavily customized by them to work with your specific platform.
I looked on HP's website and also they do not have a wireless driver available for Ubuntu 20.04.6 LTS version:
https://www.dell.com/support/home/en-us/product-support/product/precision-17-7760-laptop/drivers
Based on that, I will do further research on this matter to try to find a possible solution for this matter or to direct you to the proper department for support. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello mailsanchu, I just received an update on this matter.
While we are still working on this matter, we suggest to upgrade your kernel to the latest stable version available. If the issue continues after that, then please provide a dmesg log file.
Albert R.
mailsanchu
I am on the latest firmware for ubuntu  20.04
Alberto_R_Intel
mailsanchu, Thank you very much for your response.
We are sorry to hear the issue persists even though you are on the latest firmware for Ubuntu* 20.04.
We will be more than glad to further assist you. For us to be able to do so, please provide the dmesg log file.
Albert R.
mailsanchu
Can I send the dmesg file in private?
Alberto_R_Intel
mailsanchu, Thank you very much for your reply.
Sure, of course. I will send you an email for you to reply to it with the file. Please verify your inbox.
Albert R.
Alberto_R_Intel
While we are still working on this subject, could you please try to reset the network settings in Ubuntu? Some steps can be found here:
https://linuxhint.com/restarting_network_ubuntu/
Albert R.
mailsanchu
I have done these steps many times. No luck
Alberto_R_Intel
mailsanchu, Thank you very much for confirming those details.
We are sorry to hear the issue remains after trying those steps.
We will continue working on this case. As soon as I get more information, I will post all of it on this thread.
Albert R.
Alberto_R_Intel
After reviewing the case, for this scenario, we recommended to use the latest mainline kernel 6.2 which will contain the Wi-Fi firmware ver. 72.
If the system still can't scan the 6E channels with kernel 6.2 (Wi-Fi ver. 72), then please try to:
Update the BIOS to the latest version, and check with Dell Support if the system BIOS blocks the 6E channels:
Check this issue with Ubuntu Support or with the manufacturer of the wireless router :
https://ubuntu.com/support/community-support
Albert R.
