Wireless
8524 ディスカッション
Ubuntu AX210 is crashing after enabling 802.11ax / WiFi 6 mode
mailsanchu
初心者
7,201件の閲覧回数
Hi there,
My Intel AX210 is crashing after enabling  802.11ax / WiFi 6 mode on my ASUS AX86U.It works fine otherwise. Speeds are around 400-500Mbps on a 1Gb connection. I am attaching some basic info here. Happy to share additional info if required
svarkey@svarkey-Precision-7760:/tmp$ uname -a
Linux svarkey-Precision-7760 5.13.0-1014-oem #18-Ubuntu SMP Wed Sep 22 17:36:11 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Error stack trace
50.219422] iwlwifi 0000:92:00.0: Start IWL Error Log Dump:
[ 50.219424] iwlwifi 0000:92:00.0: Status: 0x00000040, count: 7
[ 50.219426] iwlwifi 0000:92:00.0: 0x20101A0D | ADVANCED_SYSASSERT
[ 50.219429] iwlwifi 0000:92:00.0: 0x00000000 | umac branchlink1
[ 50.219431] iwlwifi 0000:92:00.0: 0x8045CF40 | umac branchlink2
[ 50.219433] iwlwifi 0000:92:00.0: 0x010003D4 | umac interruptlink1
[ 50.219435] iwlwifi 0000:92:00.0: 0x00000000 | umac interruptlink2
[ 50.219437] iwlwifi 0000:92:00.0: 0x00000008 | umac data1
[ 50.219439] iwlwifi 0000:92:00.0: 0x00000000 | umac data2
[ 50.219441] iwlwifi 0000:92:00.0: 0x0FFF0FFF | umac data3
[ 50.219443] iwlwifi 0000:92:00.0: 0x0000003F | umac major
[ 50.219445] iwlwifi 0000:92:00.0: 0xC04F3485 | umac minor
[ 50.219447] iwlwifi 0000:92:00.0: 0x00A49B3B | frame pointer
[ 50.219449] iwlwifi 0000:92:00.0: 0xC0886BA0 | stack pointer
[ 50.219451] iwlwifi 0000:92:00.0: 0x0036050F | last host cmd
[ 50.219453] iwlwifi 0000:92:00.0: 0x00000000 | isr status reg
[ 50.219624] iwlwifi 0000:92:00.0: IML/ROM dump:
[ 50.219625] iwlwifi 0000:92:00.0: 0x00000B03 | IML/ROM error/state
[ 50.219686] iwlwifi 0000:92:00.0: 0x0000786C | IML/ROM data1
[ 50.219742] iwlwifi 0000:92:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 50.219798] iwlwifi 0000:92:00.0: Fseq Registers:
[ 50.219850] iwlwifi 0000:92:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 50.219901] iwlwifi 0000:92:00.0: 0x80440002 | FSEQ_TOP_INIT_VERSION
[ 50.219953] iwlwifi 0000:92:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 50.220004] iwlwifi 0000:92:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 50.220055] iwlwifi 0000:92:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 50.220106] iwlwifi 0000:92:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 50.220157] iwlwifi 0000:92:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 50.220209] iwlwifi 0000:92:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 50.220261] iwlwifi 0000:92:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 50.220385] iwlwifi 0000:92:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 50.220439] iwlwifi 0000:92:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 50.220493] iwlwifi 0000:92:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 50.220746] iwlwifi 0000:92:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
0 件の賞賛
15 返答(返信)
mailsanchu
初心者
7,108件の閲覧回数
91 views. No response
DeividA_Intel
従業員
7,082件の閲覧回数
Hello mailsanchu,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details:
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Is this issue recent? If so, when did it start?
4. Where are you enabling the 802.11ax/WiFi 6 mode (BIOS, OS, Asus tool)?
5. Have you checked with Asus for instructions and advice?
Deivid A.
mailsanchu
初心者
7,075件の閲覧回数
Hi Deivid,
Please find my answers below
>> Dell Precision-7760 ( https://www.dell.com/en-us/work/shop/workstations-isv-certified/precision-7760-workstation/spd/precision-17-7760-laptop)
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-op...
>> Came pre-installed
>> Not sure it ever worked
>> Router UI
>> IPhone and galaxy phones are working. Issue is observed only on Ubuntu 20.04 AX210(iwlwifi)
DeividA_Intel
従業員
7,052件の閲覧回数
Hello mailsanchu,
In order to proceed, please try and provide the following:
1. What is the brand and model name of your router?
2. Did the issue appear on windows 10/11? Or is it only limited to Linux as you mentioned?
3. Run the following commands and send us the outcome:
  • modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
  • lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
  • To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
  • dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (API mentioned in the dmesg).
  • Please visit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
4. If the above steps don't work, collect the debug data:
  • Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Deivid A.
mailsanchu
初心者
7,045件の閲覧回数
Deivid,
Firmware is working correctly for 2.4/5Ghz. So it is a firmware issue.
Does your firmware support 6GHz?
mailsanchu
初心者
7,045件の閲覧回数
>> ASUS AX86U
>> Windows 11 is OK and no issues
Attached modinfo and lsmod logs
DeividA_Intel
従業員
7,012件の閲覧回数
Hello mailsanchu,
Thank you for the information provided
Deivid A.
mailsanchu
初心者
6,993件の閲覧回数
Deivid,
Looking forward to the solution. Thank you
DeividA_Intel
従業員
6,953件の閲覧回数
Hello mailsanchu,
Based on the research perform, I would like you to try and provide the following:
1. Update to the latest firmware version 67 and check if the issue persists.
2. Check with DELL and confirm that the latest BIOS is installed.
3. Check that the AP is using the latest firmware.
4. You mentioned randomly firmware crashes during data streaming while connecting to Asus AP at 5 GHz in 20 MHz bandwidth, but 2.4 GHz works fine?
5. Does the firmware crashes after "x" hours of streaming?
Deivid A.
mailsanchu
初心者
6,946件の閲覧回数
>> How do I update the 67 firmware. Any documentation for this?
>> Yes I check this regularly
>> Don't think this is happening. Only WIFI 6 is the problem
>> Dont think this is a problem
DeividA_Intel
従業員
6,932件の閲覧回数
Hello mailsanchu,
Thanks for the information provided. In this case, I recommend you to get in contact with the Linux support team to get the steps and firmware to perform the update.
Please let me know if the issue persists after the Firmware update.
Deivid A.
mailsanchu
初心者
6,926件の閲覧回数
What do you mean by "Linux support team"? Linux support team from intel or
Not sure I follow
DeividA_Intel
従業員
6,918件の閲覧回数
Hello mailsanchu,
In this case, you need to check with DELL or with your Linux distributor (or where you downloaded the operating system) for firmware and instructions to update it.
Intel does not have a Linux driver nor provides steps or drivers/firmware.
Deivid A.
DeividA_Intel
従業員
6,869件の閲覧回数
Hello mailsanchu,
Were you able to check the previous post? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
従業員
6,850件の閲覧回数
Hello mailsanchu,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
返信
