Wireless
8846 Discussions
Unable to create a Wi-Fi 6 Hotspot (Windows 11) - AX200
Laukar
I've been wanting to create a Wifi 6 hotspot with my Wi-Fi 6 Card (AX200) for a long time, but no such option exists on W10 or W11, is this something I should raise with Microsoft in hopes they will eventually add this feature or is this something Intel might be able to add eventually?
I have Quest 2 which supports wifi-6 but I can't utilise wifi-6 with it because of this. Or am I incorrect in thinking that Wifi 6 option should even come up? Wifi 6 is supposed to utilise both 2.4 ghz and 5Ghz bands at the same time, so I doubt that Windows currently fully utilizes Wifi-6 capabilities when it comes to creating hotspots.
Laukar
DeividA_Intel
Hello Laukar,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Can other devices connect to the Wifi 6 via hotspot?
4. Can you connect to Wifi 6 directly from the router?
5. What is the brand and model name of the router?
Deivid A.
DeividA_Intel
Hello Laukar,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello Laukar,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
