Wireless
8710 Discussions
Unable to get Target Wake Time (TWT) to work for intel(R) Wi-Fi 6 AX210 160MHz.
govind123
Hi Intel team,
Similar to this, I too was trying to get TWT to work on Linux Ubuntu (22.04/20.04/18.04) with no luck. Even tried to test its functionality on Windows(10/11)
It is a Upgraded (not original)  card which was fit into the laptop. In the association frame TWT Requester support and TWT Responder Support bits are disabled
Can you please let me know how to enable individual TWT functionality on the card.
IsaacQ_Intel
Hello @ govind123
System manufacturers may have altered the features, incorporated customizations, or made other changes to the software or hardware packaging they provide. Only the manufacturer or its authorized representative can install the adapters. You should contact the laptop OEM to confirm the proper installation steps for the device and confirm if it is compatible with your system, we understand that this is the exact model.
For further information about Wireless Hardware Installation or Upgrade, check the following article: https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html
Since the thread is now under OEM scope, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Isaac Q.
