Hi All,
I am using the 12.4.4.0 Wireless Pro software utility with the 12.4.4.5 driver. My laptop is Dell Inspiron E1505 using XP Pro. Clean install, running sp3. I have been getting intermittent media disconnects for the last few months. When trying to reconnect to the profile, The proset tells me it is "unable" to connect to profile. I have ran the log function and generated the following partial log (The full log is 260 entries):
# Event,Source,Time,Error Severity,Domain,User,Description
260,S24EvMon,06/02/2010 17:50:59,Information,AppDriver,SYSTEM,Intel adapter(s) found.
259,S24EvMon,06/02/2010 17:50:59,Information,AppDriver,SYSTEM,Getting List of adapters.
258,Intel(R) Wireless Troubleshooter,06/02/2010 17:50:37,Information,General,BaiRen,Intel(R) Wireless Troubleshooter received a START_TRACE event.
257,S24EvMon,06/02/2010 17:50:37,Information,AppDriver,SYSTEM,Failed to set band type - possibly not supported in the driver.
256,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,SWCStopAuthentication - Supplicant already stopped. Stop request is ignored!
255,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,InitializeCOM - already initialized for thread ID=0x1356
254,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM, disconnected (linksys-B)
253,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,SWCStopAuthentication - Supplicant already stopped. Stop request is ignored!
252,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,StopSession
251,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,StartSession- pData=0132EC00 pbDelayStart=0132EBF8
250,Muroc Api,06/02/2010 17:50:36,Information,General,BaiRen,Profile linksys-B for linksys-B being applied.
249,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,InitializeCOM - already initialized for thread ID=0x1356
248,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,StartAuthentication- UNRECOVERABLE ERROR! swc_start_authentication FAILED (ret=-1)
247,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,InitializeCOM - already initialized for thread ID=0x1356
246,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,InitializeCOM - already initialized for thread ID=0x1356
245,SupplicantPlugin,06/02/2010 17:50:37,Information,Security,SYSTEM,InitializeCOM - already initialized for thread ID=0x1356
The two lines of interest is the swc_start_authentication failure and the failed to set band type. The router is not the issue because I have a second laptop running a different wireless card and has not had an issue during the same time my E1505 has had this problem. Does anyone know how to resolve this issue?
Thanks!
-Brian
I have not found a solution to this issue, nor was I able to interpret the log messages. A possibility, that I will attribute this is to excess heat in the WLAN module area. Since this has been a while ago, I am no longer pursuing this issue.
-Brian
