- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi, my gigabyte aorus 15g laptop equipped with Intel AX200 running on Ubuntu 20.04 often lose Wifi Connection every 2~6 hours. The wifi can not be automatically reconnected unless I switch the wifi off and on and then everything goes back normal again, but the problem persists after a few hours. The error message I try to reconnect to the wifi is "Activation of network connection failed".
I'm pretty sure this is not a hardware issue, since this laptop running on Windows 10 has no issues at all, but the problem occurs once I install the Ubuntu 20.04 (Erase Windows and install the Ubuntu 20.04). The Ubuntu has no other issues except for occasionally wifi disconnecting.
Here is my driver name and version by running "lspci" command:
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a) (Version: 1a)
My Ubuntu and kernel version:
Ubuntu 20.04, Kernel: 5.4.0-42-generic
I think it might be some driver issues of AX200 in ubuntu 20.04. Thanks if you can look into it and please ask if you need more infos.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello DavidHuang, I just wanted to check if the problem with the Wireless connection still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
DavidHuang, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance, we just wanted to confirm a few details about your system:
Which is the specific model of the laptop? There are 5 different models in there.
https://www.gigabyte.com/us/Laptop/AORUS-15G--Intel-10th-Gen/support#support-childModelsMenu
What is the model of the Router?
Is this a new computer?
Was it working fine before with Ubuntu?
Besides changing the OS, did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed on the computer?
Does the problem happen at home or work environment?
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Which is the specific model of the laptop? There are 5 different models in there:
the model is AORUS 15G YB.
It's a AC Plus Router from Singtel, you can learn more about it here , however I don't think the issue is related to router, since after disconnecting, any wifi can't be connected unless I restart the wifi.
I bought it two months ago.
Yes, it's working fine.
No changes.
It came installed on the computer.
It happen at home.
I tried to reinstall the AX200 driver on Ubuntu under this article . And I also tried to disable the wireless power saving mode on Ubuntu. It looks like after trying these 2 methods, the problem doesn't occur again(I fixed it two days ago). I will update you if I encounter the same problem again, I think the problem might occur with the AX200 on default Ubuntu 20.04. Thanks.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
DavidHuang, Thank you very much for providing that information.
Perfect, excellent, it is great to hear that it seems that after trying those two methods the problem with the Wireless connection got fixed.
Go ahead and keep monitoring the behavior of the computer and once you get the chance, please let us know the results to confirm if that is the case.
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I encounter the same problem again after 2 days, it looks like the two methods didn't resolve the problem, could you help to look into this? I will update here if you need more info, thanks.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi DavidHuang, Thank you very much for providing those results, we are sorry to hear the issue persists.
There are some logs from your system that we need to gather in order to provide further technical assistance on this matter, so we will send you an email for you to reply with those details, please verify your inbox.
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
DavidHuang, I just received an update on this matter.
Just to confirm:
-Have you tried installing the latest firmware and still seen the connection issue? e.g. "iwlwifi-cc-*ucode" firmware files are available for AX200 in the package linux-firmware-20200817.tar.gz
-Did you install dual-boot Windows 10 and Ubuntu on your system? If so, please disable the 'Fast Startup' option on Windows 10. Details can be found at https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi, please refer to "About dual-boot with Windows and "fast-boot" enabled"
-The log shows he used 'iwiwifi', but it should be 'iwlwifi'
When the issue occurs, please generate the logs with correct module 'iwlwifi'
-Please proceed the debug Step 5, it is missing from the previous log:
#dmesg | grep ASSERT
If output is empty, then please do
#dmesg > dmesg.log
#sudo trace-cmd record -e iwlwifi
And collect the dmesg.log and the trace.dat
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello DavidHuang, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Albert,
I just saw your message, I already install the latest firmware and see if it will help resolve the issue, I will update here with all the required debug message here if the problem persists. Thank you very much.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi DavidHuang, You are very welcome, thank you very much for sharing those updates.
Perfect, no problem, go ahead and monitor the Wireless connection and once you get the chance please let us know the results.
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Alberto,
I haven't see any issues for now after upgrading to the latest kernel. I will post another issue if the problem occurs in the future. Thank you very much for your help!
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi DavidHuang, You are very welcome, thank you very much for letting us know those updates.
Perfect, excellent, it is great to hear that there are no more issues with the Wireless connection after upgrading to the latest kernel and the computer is now working properly.
Any other inquiries, do not hesitate to contact us again.
Albert R.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
i have the some problem.
The module is recognized:
lspci -nnk | grep 0280 -A3
03:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200 [8086:0080]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
demsg output:
[ 4.244650] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 4.255299] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 4.264301] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 4.264320] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[ 4.264326] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 4.264328] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 4.264756] iwlwifi 0000:03:00.0: loaded firmware version 55.d9698065.0 cc-a0-55.ucode op_mode iwlmvm
[ 4.264804] iwlwifi 0000:03:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 4.333261] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 5.467607] iwlwifi 0000:03:00.0: SecBoot CPU1 Status: 0x4, CPU2 Status: 0x1
[ 5.467652] iwlwifi 0000:03:00.0: UMAC PC: 0xc00c0eb2
[ 5.467663] iwlwifi 0000:03:00.0: LMAC PC: 0x0
[ 5.467667] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired.
[ 5.496635] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 5.496642] iwlwifi 0000:03:00.0: Status: 0x00000000, count: -30381588
[ 5.496645] iwlwifi 0000:03:00.0: Loaded firmware version: 55.d9698065.0 cc-a0-55.ucode
[ 5.496649] iwlwifi 0000:03:00.0: 0xCB7095F2 | ADVANCED_SYSASSERT
[ 5.496652] iwlwifi 0000:03:00.0: 0x2C7B2027 | trm_hw_status0
[ 5.496654] iwlwifi 0000:03:00.0: 0x5434F58F | trm_hw_status1
[ 5.496657] iwlwifi 0000:03:00.0: 0xEF42C364 | branchlink2
[ 5.496659] iwlwifi 0000:03:00.0: 0xF1FD4FF2 | interruptlink1
[ 5.496661] iwlwifi 0000:03:00.0: 0xA879B6EB | interruptlink2
[ 5.496663] iwlwifi 0000:03:00.0: 0x118D94CF | data1
[ 5.496665] iwlwifi 0000:03:00.0: 0xB85BF05B | data2
[ 5.496667] iwlwifi 0000:03:00.0: 0x011A15FE | data3
[ 5.496669] iwlwifi 0000:03:00.0: 0x5B1874B6 | beacon time
[ 5.496673] iwlwifi 0000:03:00.0: 0x56BAF114 | tsf low
[ 5.496675] iwlwifi 0000:03:00.0: 0x34B6A702 | tsf hi
[ 5.496676] iwlwifi 0000:03:00.0: 0x89E4C338 | time gp1
[ 5.496678] iwlwifi 0000:03:00.0: 0xE152FF48 | time gp2
[ 5.496680] iwlwifi 0000:03:00.0: 0xC5451E56 | uCode revision type
[ 5.496682] iwlwifi 0000:03:00.0: 0xDD83B686 | uCode version major
[ 5.496684] iwlwifi 0000:03:00.0: 0x813C3C6E | uCode version minor
[ 5.496686] iwlwifi 0000:03:00.0: 0xCBB81852 | hw version
[ 5.496688] iwlwifi 0000:03:00.0: 0x961EDDB6 | board version
[ 5.496690] iwlwifi 0000:03:00.0: 0x4D9709DB | hcmd
[ 5.496693] iwlwifi 0000:03:00.0: 0xEA4C9BDA | isr0
[ 5.496695] iwlwifi 0000:03:00.0: 0x5CACEAB7 | isr1
[ 5.496696] iwlwifi 0000:03:00.0: 0x48F599E6 | isr2
[ 5.496698] iwlwifi 0000:03:00.0: 0x9FB6075F | isr3
[ 5.496700] iwlwifi 0000:03:00.0: 0xE690EA36 | isr4
[ 5.496703] iwlwifi 0000:03:00.0: 0x1607DE17 | last cmd Id
[ 5.496704] iwlwifi 0000:03:00.0: 0x614C9A6C | wait_event
[ 5.496706] iwlwifi 0000:03:00.0: 0x1700BF32 | l2p_control
[ 5.496708] iwlwifi 0000:03:00.0: 0x02A6216C | l2p_duration
[ 5.496710] iwlwifi 0000:03:00.0: 0x8483CA25 | l2p_mhvalid
[ 5.496713] iwlwifi 0000:03:00.0: 0x42E2AB73 | l2p_addr_match
[ 5.496715] iwlwifi 0000:03:00.0: 0x911833D7 | lmpm_pmg_sel
[ 5.496716] iwlwifi 0000:03:00.0: 0x0931F64D | timestamp
[ 5.496718] iwlwifi 0000:03:00.0: 0x4D4E4B5D | flow_handler
[ 5.496829] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 5.496831] iwlwifi 0000:03:00.0: Status: 0x00000000, count: 7
[ 5.496834] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 5.496836] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
[ 5.496838] iwlwifi 0000:03:00.0: 0x80465826 | umac branchlink2
[ 5.496840] iwlwifi 0000:03:00.0: 0x00000000 | umac interruptlink1
[ 5.496842] iwlwifi 0000:03:00.0: 0x804836C4 | umac interruptlink2
[ 5.496844] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
[ 5.496846] iwlwifi 0000:03:00.0: 0x804836C4 | umac data2
[ 5.496848] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
[ 5.496850] iwlwifi 0000:03:00.0: 0x00000037 | umac major
[ 5.496852] iwlwifi 0000:03:00.0: 0xD9698065 | umac minor
[ 5.496854] iwlwifi 0000:03:00.0: 0x0011852C | frame pointer
[ 5.496856] iwlwifi 0000:03:00.0: 0xC0887F40 | stack pointer
[ 5.496858] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
[ 5.496860] iwlwifi 0000:03:00.0: 0x00000000 | isr status reg
[ 5.496948] iwlwifi 0000:03:00.0: Fseq Registers:
[ 5.496993] iwlwifi 0000:03:00.0: 0x20000000 | FSEQ_ERROR_CODE
[ 5.497038] iwlwifi 0000:03:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 5.497083] iwlwifi 0000:03:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 5.497128] iwlwifi 0000:03:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 5.497173] iwlwifi 0000:03:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 5.497219] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 5.497264] iwlwifi 0000:03:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 5.497309] iwlwifi 0000:03:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 5.497354] iwlwifi 0000:03:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 5.497401] iwlwifi 0000:03:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 5.497449] iwlwifi 0000:03:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 5.497496] iwlwifi 0000:03:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 5.497544] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 6.062605] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
[ 160.752334] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 160.752414] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-55.ucode failed with error -2
[ 160.752480] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-54.ucode failed with error -2
[ 160.752537] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-53.ucode failed with error -2
[ 160.752590] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-52.ucode failed with error -2
[ 160.752645] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-51.ucode failed with error -2
[ 160.752699] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[ 160.752759] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[ 160.752815] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-48.ucode failed with error -2
[ 160.752874] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-47.ucode failed with error -2
[ 160.756545] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 160.756549] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 160.756980] iwlwifi 0000:03:00.0: loaded firmware version 46.177b3e46.0 cc-a0-46.ucode op_mode iwlmvm
[ 160.757017] iwlwifi 0000:03:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 160.777765] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 160.791692] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 160.792695] iwlwifi 0000:03:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 161.805500] iwlwifi 0000:03:00.0: SecBoot CPU1 Status: 0x4, CPU2 Status: 0x1
[ 161.805521] iwlwifi 0000:03:00.0: UMAC PC: 0xc00c0eb2
[ 161.805538] iwlwifi 0000:03:00.0: LMAC PC: 0x0
[ 161.805544] iwlwifi 0000:03:00.0: Collecting data: trigger 15 fired.
[ 161.834603] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 161.834612] iwlwifi 0000:03:00.0: Status: 0x00000000, count: -257729366
[ 161.834617] iwlwifi 0000:03:00.0: Loaded firmware version: 46.177b3e46.0 cc-a0-46.ucode
[ 161.834622] iwlwifi 0000:03:00.0: 0x5BB97162 | ADVANCED_SYSASSERT
[ 161.834627] iwlwifi 0000:03:00.0: 0x70E4BCAF | trm_hw_status0
[ 161.834631] iwlwifi 0000:03:00.0: 0x3DF8DB59 | trm_hw_status1
[ 161.834634] iwlwifi 0000:03:00.0: 0x7842B269 | branchlink2
[ 161.834638] iwlwifi 0000:03:00.0: 0x83706905 | interruptlink1
[ 161.834641] iwlwifi 0000:03:00.0: 0x26F5936D | interruptlink2
[ 161.834645] iwlwifi 0000:03:00.0: 0xABB85580 | data1
[ 161.834648] iwlwifi 0000:03:00.0: 0xC02E67FE | data2
[ 161.834652] iwlwifi 0000:03:00.0: 0x58C4500D | data3
[ 161.834655] iwlwifi 0000:03:00.0: 0x2CE5465D | beacon time
[ 161.834658] iwlwifi 0000:03:00.0: 0x9E66087A | tsf low
[ 161.834662] iwlwifi 0000:03:00.0: 0x6955F63B | tsf hi
[ 161.834665] iwlwifi 0000:03:00.0: 0x79A4223A | time gp1
[ 161.834668] iwlwifi 0000:03:00.0: 0x579769FA | time gp2
[ 161.834671] iwlwifi 0000:03:00.0: 0x88E07D54 | uCode revision type
[ 161.834675] iwlwifi 0000:03:00.0: 0xF645F4BF | uCode version major
[ 161.834678] iwlwifi 0000:03:00.0: 0x13DEBC10 | uCode version minor
[ 161.834681] iwlwifi 0000:03:00.0: 0x392FB34B | hw version
[ 161.834685] iwlwifi 0000:03:00.0: 0x8C9AA1CA | board version
[ 161.834688] iwlwifi 0000:03:00.0: 0x477465F1 | hcmd
[ 161.834691] iwlwifi 0000:03:00.0: 0x35FCE0FE | isr0
[ 161.834695] iwlwifi 0000:03:00.0: 0xAFF8F5CB | isr1
[ 161.834698] iwlwifi 0000:03:00.0: 0xDCC1675F | isr2
[ 161.834701] iwlwifi 0000:03:00.0: 0x4DCEF62C | isr3
[ 161.834704] iwlwifi 0000:03:00.0: 0x6D3FF544 | isr4
[ 161.834707] iwlwifi 0000:03:00.0: 0x77C467C6 | last cmd Id
[ 161.834711] iwlwifi 0000:03:00.0: 0xA179877B | wait_event
[ 161.834714] iwlwifi 0000:03:00.0: 0x1573F851 | l2p_control
[ 161.834717] iwlwifi 0000:03:00.0: 0x793C7363 | l2p_duration
[ 161.834721] iwlwifi 0000:03:00.0: 0x352FB6B5 | l2p_mhvalid
[ 161.834724] iwlwifi 0000:03:00.0: 0xB85DAA9E | l2p_addr_match
[ 161.834727] iwlwifi 0000:03:00.0: 0x84697C6C | lmpm_pmg_sel
[ 161.834730] iwlwifi 0000:03:00.0: 0xA866F1EF | timestamp
[ 161.834734] iwlwifi 0000:03:00.0: 0x52A1BF22 | flow_handler
[ 161.834850] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 161.834854] iwlwifi 0000:03:00.0: Status: 0x00000000, count: 7
[ 161.834857] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 161.834861] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
[ 161.834864] iwlwifi 0000:03:00.0: 0xC008B1C0 | umac branchlink2
[ 161.834867] iwlwifi 0000:03:00.0: 0x00000000 | umac interruptlink1
[ 161.834871] iwlwifi 0000:03:00.0: 0xC008B51A | umac interruptlink2
[ 161.834874] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
[ 161.834878] iwlwifi 0000:03:00.0: 0xC008B51A | umac data2
[ 161.834881] iwlwifi 0000:03:00.0: 0xDEADBEEF | umac data3
[ 161.834885] iwlwifi 0000:03:00.0: 0x0000002E | umac major
[ 161.834888] iwlwifi 0000:03:00.0: 0x177B3E46 | umac minor
[ 161.834891] iwlwifi 0000:03:00.0: 0x000FE141 | frame pointer
[ 161.834895] iwlwifi 0000:03:00.0: 0xC0887F60 | stack pointer
[ 161.834898] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
[ 161.834901] iwlwifi 0000:03:00.0: 0x00000000 | isr status reg
[ 161.834990] iwlwifi 0000:03:00.0: Fseq Registers:
[ 161.835037] iwlwifi 0000:03:00.0: 0x60005101 | FSEQ_ERROR_CODE
[ 161.835083] iwlwifi 0000:03:00.0: 0x00290021 | FSEQ_TOP_INIT_VERSION
[ 161.835128] iwlwifi 0000:03:00.0: 0x80050008 | FSEQ_CNVIO_INIT_VERSION
[ 161.835175] iwlwifi 0000:03:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 161.835221] iwlwifi 0000:03:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 161.835266] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 161.835312] iwlwifi 0000:03:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 161.835357] iwlwifi 0000:03:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 161.835403] iwlwifi 0000:03:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 161.835451] iwlwifi 0000:03:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 161.835499] iwlwifi 0000:03:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 161.835546] iwlwifi 0000:03:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 161.835594] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 161.835635] iwlwifi 0000:03:00.0: Collecting data: trigger 16 fired.
[ 163.096927] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
[ 253.761234] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 253.761763] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 253.761779] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[ 253.761783] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 253.761786] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 253.762227] iwlwifi 0000:03:00.0: loaded firmware version 55.d9698065.0 cc-a0-55.ucode op_mode iwlmvm
[ 253.762253] iwlwifi 0000:03:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 253.783530] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 254.805871] iwlwifi 0000:03:00.0: SecBoot CPU1 Status: 0x4, CPU2 Status: 0x1
[ 254.805894] iwlwifi 0000:03:00.0: UMAC PC: 0xc00c0eb2
[ 254.805910] iwlwifi 0000:03:00.0: LMAC PC: 0x0
[ 254.805917] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired.
[ 254.834977] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 254.834986] iwlwifi 0000:03:00.0: Status: 0x00000000, count: -55547412
[ 254.834991] iwlwifi 0000:03:00.0: Loaded firmware version: 55.d9698065.0 cc-a0-55.ucode
[ 254.834996] iwlwifi 0000:03:00.0: 0xCB70B5F6 | ADVANCED_SYSASSERT
[ 254.835001] iwlwifi 0000:03:00.0: 0x2C7B6127 | trm_hw_status0
[ 254.835005] iwlwifi 0000:03:00.0: 0x5474B48F | trm_hw_status1
[ 254.835008] iwlwifi 0000:03:00.0: 0xE742C364 | branchlink2
[ 254.835012] iwlwifi 0000:03:00.0: 0xF19D5FF2 | interruptlink1
[ 254.835015] iwlwifi 0000:03:00.0: 0xA8F9B6EB | interruptlink2
[ 254.835019] iwlwifi 0000:03:00.0: 0x118D96CF | data1
[ 254.835022] iwlwifi 0000:03:00.0: 0xB45BF05B | data2
[ 254.835026] iwlwifi 0000:03:00.0: 0x015A15FA | data3
[ 254.835029] iwlwifi 0000:03:00.0: 0x5B19742E | beacon time
[ 254.835033] iwlwifi 0000:03:00.0: 0x46BEF915 | tsf low
[ 254.835036] iwlwifi 0000:03:00.0: 0x34B22722 | tsf hi
[ 254.835039] iwlwifi 0000:03:00.0: 0x89E4E378 | time gp1
[ 254.835042] iwlwifi 0000:03:00.0: 0xE15AFF48 | time gp2
[ 254.835046] iwlwifi 0000:03:00.0: 0xC5451ED6 | uCode revision type
[ 254.835049] iwlwifi 0000:03:00.0: 0xDD83B284 | uCode version major
[ 254.835052] iwlwifi 0000:03:00.0: 0x813C3C2E | uCode version minor
[ 254.835056] iwlwifi 0000:03:00.0: 0xDBB8B852 | hw version
[ 254.835059] iwlwifi 0000:03:00.0: 0x961EDDB6 | board version
[ 254.835062] iwlwifi 0000:03:00.0: 0x4D9709DB | hcmd
[ 254.835066] iwlwifi 0000:03:00.0: 0xEBCCBBDA | isr0
[ 254.835069] iwlwifi 0000:03:00.0: 0x4EACEAB7 | isr1
[ 254.835072] iwlwifi 0000:03:00.0: 0x42F599E6 | isr2
[ 254.835075] iwlwifi 0000:03:00.0: 0x97B6071F | isr3
[ 254.835078] iwlwifi 0000:03:00.0: 0xE692E276 | isr4
[ 254.835082] iwlwifi 0000:03:00.0: 0x1607EE16 | last cmd Id
[ 254.835085] iwlwifi 0000:03:00.0: 0x710C9A6D | wait_event
[ 254.835088] iwlwifi 0000:03:00.0: 0x1700BF22 | l2p_control
[ 254.835091] iwlwifi 0000:03:00.0: 0x10A6216E | l2p_duration
[ 254.835095] iwlwifi 0000:03:00.0: 0x9483C220 | l2p_mhvalid
[ 254.835098] iwlwifi 0000:03:00.0: 0x42E3AB63 | l2p_addr_match
[ 254.835101] iwlwifi 0000:03:00.0: 0x9158B3D7 | lmpm_pmg_sel
[ 254.835104] iwlwifi 0000:03:00.0: 0x0931F66D | timestamp
[ 254.835108] iwlwifi 0000:03:00.0: 0x4F4E497D | flow_handler
[ 254.835224] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 254.835228] iwlwifi 0000:03:00.0: Status: 0x00000000, count: 7
[ 254.835232] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 254.835236] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
[ 254.835239] iwlwifi 0000:03:00.0: 0x80465826 | umac branchlink2
[ 254.835242] iwlwifi 0000:03:00.0: 0x00000000 | umac interruptlink1
[ 254.835246] iwlwifi 0000:03:00.0: 0x804836C4 | umac interruptlink2
[ 254.835249] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
[ 254.835252] iwlwifi 0000:03:00.0: 0x804836C4 | umac data2
[ 254.835256] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
[ 254.835259] iwlwifi 0000:03:00.0: 0x00000037 | umac major
[ 254.835262] iwlwifi 0000:03:00.0: 0xD9698065 | umac minor
[ 254.835266] iwlwifi 0000:03:00.0: 0x000FD024 | frame pointer
[ 254.835269] iwlwifi 0000:03:00.0: 0xC0887F40 | stack pointer
[ 254.835272] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
[ 254.835276] iwlwifi 0000:03:00.0: 0x00000000 | isr status reg
[ 254.835364] iwlwifi 0000:03:00.0: Fseq Registers:
[ 254.835411] iwlwifi 0000:03:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 254.835457] iwlwifi 0000:03:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 254.835503] iwlwifi 0000:03:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 254.835548] iwlwifi 0000:03:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 254.835594] iwlwifi 0000:03:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 254.835640] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 254.835685] iwlwifi 0000:03:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 254.835731] iwlwifi 0000:03:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 254.835777] iwlwifi 0000:03:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 254.835824] iwlwifi 0000:03:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 254.835872] iwlwifi 0000:03:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 254.835920] iwlwifi 0000:03:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 254.835967] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 255.378371] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
best regards
