Wireless
8622 Discussions
WPA unicast rekey issues with 6300?
My clients connect fine using WPA on the 6300 on Windows 7 (driver version 14.0.1.2). However, unicast rekeys fail because the card does not respond to the key messages from the AP. This works fine with WPA2. Group rekeys also work fine. Is this a known issue?
Vineet
Hello Vineet!
In order to assist you better, can you tell me how many systems are affected by this behavior?
What is the Operating System you're using?
Also, are you a Corporate user?
Cheers!
Hi Stitchz,
Thanks you for your response. This problem occurs on our Windows 7 laptops. It does not happen when using the card on Linux.
I am a corporate user.
-Vineet
Vineet,
I sent you a private message requesting more data, so reply to me as soon as you can.
Cheers!
