Wireless
公告
8851 讨论
Which special driver version need to support be200 mlo features.
vernon
新手
6,615 次查看
Good afternoon
I am using wifi7 network card be200 on Ubuntu24.04.But i can't find Mlo function of be200 work.
I use command "iw dev  interface_name info",but i can't see something like link0,link1.
But when I try with system win11 24h2,i input command "netsh wlan show interfaces",I can see link0 link1 these things.
what additional configuration is required to make mlo functions work on ubuntu?
Those are my device and driver infomation:
kernel:
Linux  6.8.0-39-generic
driver:iwlwifi
driverversion:6.8.0-39-generic
firmware:86.fb5c9aeb.0 gl-c0-fm-c0-86.uc
lspci:Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 (rev 1a)
0 项奖励
8 回复数
vernon
新手
6,520 次查看
After update the os version to 6.11 and update firmware,the mlo feature can work.
This post can be closed.
0 项奖励
nlee
初学者
6,131 次查看
hi,
what is the firmare on you device ?
i updated to 6.11, but still can not found mlo , even back to he without eht.
my info :
*-network
description: Ethernet interface
product: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0f0
version: 1a
serial: 10:91:d1:52:61:47
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=6.11.0-061100-generic firmware=90.38c93dbc.0 gl-c0-fm-c0-90.uc ip=192.168.1.101 latency=0 link=yes multicast=yes
resources: irq:16 memory:74200000-74203fff
0 项奖励
vernon
新手
5,922 次查看
It is seems ok for your driverversion and firmware version,What's the version of your wpa_supplicant?It need to update to 2.12.In 2.12,wpa_supplicant just start to support wifi7
0 项奖励
Zack1991
初学者
5,141 次查看
Then how to upgrade wpa supplicant from v2.10 to v2.12?
0 项奖励
Zack1991
初学者
6,045 次查看
Hi Vernon,
How did you update the firmware on 6.11? Do you have the driver that can share with us?
0 项奖励
vernon
新手
5,922 次查看
For Linux,you can just update kernel,then the driver version will update too.For the firmware, you can download from kernel/git/iwlwifi/linux-firmware.git - iwlwifi linux-firmware tree - for linux-firmware,choose iwlwifi-gl-c0-fm-c0-90.ucode
0 项奖励
miguelrincon
初学者
5,893 次查看
How do you know MLO feature is enabled? Is there any propertie shown?
My ubuntu client is connected to a MLD AP but i cannot see any MLO information on the client.
I have the following device and drivers information:
*-network
descripción: Ethernet interface
producto: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
fabricante: Intel Corporation
id físico: 0
información del bus: pci@0000:02:00.0
nombre lógico: wlp2s0f0
versión: 1a
serie: c8:15:4e:27:1c:0d
anchura: 64 bits
reloj: 33MHz
capacidades: pm msi pciexpress msix bus_master cap_list ethernet physical
configuración: broadcast=yes driver=iwlwifi driverversion=6.11.0-8-generic firmware=92.67ce4588.0 gl-c0-fm-c0-92.uc ip=192.168.54.251 latency=0 link=yes multicast=yes
recursos: irq:17 memoria:91200000-91203fff
wpa_supplicant v2.11
Copyright (c) 2003-2024, Jouni Malinen <j@w1.fi> and contributors
Thank you.
0 项奖励
vernon
新手
5,806 次查看
MLO means Multi Link Operation,I just check by command iw dev interface_name info,then if you can see over one link,thats means mlo feature is enabled.
0 项奖励
回复
