Wireless
8661 Discussions
Which special driver version need to support be200 mlo features.
vernon
Good afternoon
I am using wifi7 network card be200 on Ubuntu24.04.But i can't find Mlo function of be200 work.
I use command "iw dev  interface_name info",but i can't see something like link0,link1.
But when I try with system win11 24h2,i input command "netsh wlan show interfaces",I can see link0 link1 these things.
what additional configuration is required to make mlo functions work on ubuntu?
Those are my device and driver infomation:
kernel:
Linux  6.8.0-39-generic
driver:iwlwifi
driverversion:6.8.0-39-generic
firmware:86.fb5c9aeb.0 gl-c0-fm-c0-86.uc
lspci:Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 (rev 1a)
vernon
After update the os version to 6.11 and update firmware,the mlo feature can work.
This post can be closed.
nlee
hi,
what is the firmare on you device ?
i updated to 6.11, but still can not found mlo , even back to he without eht.
my info :
*-network
description: Ethernet interface
product: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0f0
version: 1a
serial: 10:91:d1:52:61:47
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=6.11.0-061100-generic firmware=90.38c93dbc.0 gl-c0-fm-c0-90.uc ip=192.168.1.101 latency=0 link=yes multicast=yes
resources: irq:16 memory:74200000-74203fff
vernon
It is seems ok for your driverversion and firmware version,What's the version of your wpa_supplicant?It need to update to 2.12.In 2.12,wpa_supplicant just start to support wifi7
Zack1991
Then how to upgrade wpa supplicant from v2.10 to v2.12?
Zack1991
Hi Vernon,
How did you update the firmware on 6.11? Do you have the driver that can share with us?
vernon
For Linux,you can just update kernel,then the driver version will update too.For the firmware, you can download from kernel/git/iwlwifi/linux-firmware.git - iwlwifi linux-firmware tree - for linux-firmware,choose iwlwifi-gl-c0-fm-c0-90.ucode
miguelrincon
How do you know MLO feature is enabled? Is there any propertie shown?
My ubuntu client is connected to a MLD AP but i cannot see any MLO information on the client.
I have the following device and drivers information:
*-network
descripción: Ethernet interface
producto: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
fabricante: Intel Corporation
id físico: 0
información del bus: pci@0000:02:00.0
nombre lógico: wlp2s0f0
versión: 1a
serie: c8:15:4e:27:1c:0d
anchura: 64 bits
reloj: 33MHz
capacidades: pm msi pciexpress msix bus_master cap_list ethernet physical
configuración: broadcast=yes driver=iwlwifi driverversion=6.11.0-8-generic firmware=92.67ce4588.0 gl-c0-fm-c0-92.uc ip=192.168.54.251 latency=0 link=yes multicast=yes
recursos: irq:17 memoria:91200000-91203fff
wpa_supplicant v2.11
Copyright (c) 2003-2024, Jouni Malinen <j@w1.fi> and contributors
Thank you.
vernon
MLO means Multi Link Operation,I just check by command iw dev interface_name info,then if you can see over one link,thats means mlo feature is enabled.
