Wireless
8651 Discussions
Why doesn't my Intel BE200 support Wi-Fi 7 in Linux?
ningl
May I ask why my Intel BE200 doesn't support Wi-Fi 7 in the Linux environment? My Linux kernel version is 6.14.0. The regulatory information is as follows, and please see the attachment for the ssu.sh check results. Could you please help me take a look? I urgently need to use Wi-Fi 7 in my Linux system.
global
country 00: DFS-UNSET
(755 - 928 @ 2), (N/A, 20), (N/A), PASSIVE-SCAN
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country CN: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5490 - 5510 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5510 - 5530 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5530 - 5550 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5550 - 5570 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5570 - 5590 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5590 - 5610 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5610 - 5630 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5630 - 5650 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5735 - 5755 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5755 - 5775 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5775 - 5795 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5795 - 5815 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5815 - 5835 @ 100), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
JedG_Intel
Hello ningl,
It appears that you're having issues connecting to Wi-Fi 7, and I understand how important this is to you. To address the issue effectively, kindly share the information below.
1. Was this working fine before?
2. Are you able to utilize Wi-Fi 7 with Windows environment?
3. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
4. Is this a laptop or desktop system?
5. What troubleshooting steps have you performed so far?
Best regards
Jed G.
ningl
==>Never worked properly;
==>Has not been tested in a Windows environment;
ubuntu pre-installed
pi5
no
JedG_Intel
Hello ningl,
Thank you for sharing all this information. Let me just clear this out, is the BE200 pre-installed on the system or was this installed recently?
Additionally, please try to install the latest Kernel version 6.16 at The Linux Kernel Archives and the latest firmware at Firmware git tree.
Firmware versions:
- iwlwifi-gl-c0-fm-c0-1001
- iwlwifi-gl-c0-fm-c0.pnvm
If you have any questions, please let me know.
Best regards
Jed G.
JedG_Intel
Hi ningl,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
JedG_Intel
Hello ningl,
Kindly try the latest Kernel and Firmware from the link that I shared previously and if the issue continuous to persist, kindly contact OS manufacturer for further assistance.
Also, we have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jed G.
Freyann
I bought a Lenovo Yoga Pro 7 14IAH10 laptop - 14" Ultra-Thin 3K OLED 120Hz Touchscreen Laptop (Intel Arrow Ultra 9H)
MY card is an Intel Wi-Fi 6E AX211 / AX210 (Raptor Lake / Meteor Lake)
I have the same problem: the Wi-Fi works, but it disappears when the laptop goes to sleep, closes the lid, etc.
Log:
Failed to start RT ucode: -110
557.889628] iwlwifi 0000:01:00.0: HW_REV=0xFFFFFFFF, PCI issues? [ 557.889636] iwlwifi: probe of 0000:01:00.0 failed with error -5 [ 561.375944] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 561.376023] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [561.376084] Loaded iwlwifi 0000:01:00.0: Unable to change Power state from D3cold to D0, device inaccessible [561.382855] iwlwifi 0000:01:00.0: HW_REV=0xFFFFFFFF, PCI issues?
I tried with Ubuntu 20.04, 22.04, and 24.04
several kernels and firmwares
I tried several things:
rfkill unblock all
modprobe -r iwlmvm iwlwifi
modprobe iwlwifi
modprobe iwlmvm
ip link set wlp1s0f0 up
systemctl restart NetworkManager
nmcli device wifi rescan
i tested   iwlwifi-gl-c0-fm-c0-92.ucode /lib/firmware/
