Here is the info: I just changed routers and it's still happening. only on my HP envy laptop.
I did change the setting from public network to private. (home or office)
SSID: Linksys03209
Protocol: 802.11n
Security type: WPA2-Personal
Network band: 2.4 GHz
Network channel: 3
IPv6 address: 2406:3003:2060:1820:3cd6:8357:408c:db23
IPv6 DNS servers: 2406:3003:2060:1820:26f5:a2ff:fe90:8bd6
IPv4 address: 192.168.1.149
IPv4 DNS servers: 192.168.1.1
Manufacturer: Intel Corporation
Description: Intel(R) Dual Band Wireless-AC 7260
Driver version: 18.33.14.3
Physical address (MAC): AC-FD-CE-3E-70-E7
5G
SSID: Linksys03209_5GHz
Protocol: 802.11ac
Network band: 5 GHz
Network channel: 108
During this email, my network disconnected again. attached is the screen shot of diagnostics. Usually it's reset wifi adapter.
Thx Diego, I'll give it a try. I have uninstalled prior but it always told me that i had the latest drivers available.
Hope it works..I'll revert back to you.
Hi Diego, I did a clean install last week. I wanted to give it time to see if the prob;em has been solved.
All was good until this AM. PFA screen shot. Usually the issue was reset adapter, this time it was default gateway.
I believe my power saving settings are correct, but my battery will inadvertently stop charging. (plugged in, not charging)
I shut down, drain the the battery (integrated) and plug-in to ac adapter. This fixes the charging issue temporarily. Not sure if this is related??
Appreciate your help.
Hi Diego, give this a couple of days...I just unchecked power management "allow to turn off"
I forgot to do this after the re-install. With the battery issue, it most likely caused the recent disconnect.
Thx again for all your help!
Hi Diego,
After I did the clean re-install. It was fine for a approx one week.
Now it's happening daily, several times per day.
Any suggestions?
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
