Wireless
8871 Discussions
Wi-Fi 7 BE200 MLO Capability question
Eliot_C
I would like to use MLO 5G 160 + 6G 160 and 2G 40 + 6G 160.
Could you let me know whole MLO capability of BE200?
Eliot
ACarmona_Intel
Hello Eliot_C,
Please allow me time to further investigate our concern; I'll get back to you as soon as I already have the answer on our case.
Carmona A.
ACarmona_Intel
Hello Eliot_C,
Thank you so much for patiently waiting on my response.
In order for me to provide you the appropriate information for your query, please provide the following information below:
  • Is your PC self-integrated or preinstalled?
  • What is the make and model of your router?
  • In order for me to check your advanced settings using PowerShell, please follow the steps below:
  1. Type in Windows PowerShell in your Windows search bar; right-click, then choose run as administrator.
  2. Once you are already inside the PowerShell, please type this command: Get-NetAdapterAdvancedProperty | Where-Object -Property Name -Contains 'Wi-Fi' | Format-Table OR Get-NetAdapterAdvancedProperty -Name "Wi-Fi" | Format-Table
           Remark: Wireless adapter advanced settings list. *Wi-Fi 4, 5, 6, 6E and Wi-Fi 7. Note: for some systems WLAN instead of Wi-Fi is applicable.
      3. Please share with me the screenshot.
Carmona A.
Eliot_C
Thanks for your answer.
Here is PC model name : Lenovo Thinkpad P1 Gen7
Please, help to check below capture;
WiFi7 AP is connected with the laptop.
every comment is Korean, but there is nothing related to WiFi7.
활성화 is Activated. 비활성화 is Deactivated.
and it says 802.11ax EHT, although EHT is 11be thing.
Eliot
ACarmona_Intel
Hello Eliot_C,
Thank you so much for your cooperation.
After reviewing your response, I couldn't find your SSU logs.
Is it possible that you can also share it with me? since your SSU contains your system specifications and configurations that will greatly help with the investigation.
Furthermore, is it okay if you copy and paste the output from the PowerShell? As I can only understand the English language and am unable to double-check the output on the PowerShell.
And by the way, is your PC self-integrated or preinstalled? And what is the make and model of your router?
Carmona A.
ACarmona_Intel
Hello Eliot_C,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Thank you.
Carmona A.
Eliot_C
Hello Carmona A,
Korea Lunar holiday season was finished just 3days ago.
Let me check your comment and get back to you.
Eliot
ACarmona_Intel
Hello Eliot_C,
Highly noted.
Carmona A.
Eliot_C
Please, check attached log file and below power-shell log;
PS C:\Windows\system32> Get-NetAdapterAdvancedProperty | Where-Object -Property Name -Contains 'Wi-Fi' | Format-Table
Name                      DisplayName                    DisplayValue                   RegistryKeyword RegistryValue
Wi-Fi                     WoWLAN 연결 해제 시 절전 상태  비활성화함                     *DeviceSleep... {0}
Wi-Fi                     패킷 통합                      활성화함                       *PacketCoale... {1}
Wi-Fi                     WoWLAN에 대한 ARP 오프로드     활성화함                       *PMARPOffload   {1}
Wi-Fi                     WoWLAN에 대한 NS 오프로드      활성화함                       *PMNSOffload    {1}
Wi-Fi                     WoWLAN에 대한 GTK 키 재입력    활성화함                       *PMWiFiRekey... {1}
Wi-Fi                     Wake on 매직 패킷              활성화함                       *WakeOnMagic... {1}
Wi-Fi                     Wake on 패턴 일치              활성화함                       *WakeOnPattern  {1}
Wi-Fi                     2.4GHz 채널 폭                 자동                           ChannelWidth24  {1}
Wi-Fi                     5GHz 채널 폭                   자동                           ChannelWidth52  {1}
Wi-Fi                     6GHz 채널 폭                   자동                           ChannelWidth6   {1}
Wi-Fi                     혼합 모드 보호                 RTS/CTS 활성화함               CtsToItself     {0}
Wi-Fi                     과부하 채널 비지원             비활성화함                     FatChannelIn... {0}
Wi-Fi                     전송 전원                      5. 최고                        IbssTxPower     {100}
Wi-Fi                     802.11n/ac/ax/ax EHT 무선 모드 5. 802.11ax EHT                IEEE11nMode     {4}
Wi-Fi                     초고대역 (6GHz)                활성화함                       Is6GhzBandSu... {1}
Wi-Fi                     MIMO 절전 모드                 자동 SMPS                      MIMOPowerSav... {0}
Wi-Fi                     로밍의 주동성                  3. 보통                        RoamAggressi... {2}
Wi-Fi                     기본 설정 밴드                 1. 기본 설정 없음              RoamingPrefe... {0}
Wi-Fi                     처리량 부스터                  비활성화함                     ThroughputBo... {0}
Wi-Fi                     U-APSD 지원                    비활성화함                     uAPSDSupport    {0}
Wi-Fi                     802.11a/b/g 무선 모드          6. 듀얼 밴드 802.11a/b/g       WirelessMode    {34}
ACarmona_Intel
Hello Eliot_C,
Thank you so much for the response and for your cooperation.
This will be the last information that I am going to ask you for before I deeply investigate our issue:
Once provided, I will then focus on deeply investigating our case.
Carmona A.
VonM_Intel
Hello Eliot_C,
Von M.
Eliot_C
I already shared my laptop model name : Lenovo Thinkpad P1 Gen7
And WiFi card is preinstalled one.
Please, help to check my initial question.
My question is just whether Intel has any plan to support MLO.
Eliot
VonM_Intel
Hello Eliot_C,
Thank you and apologize for any confusion earlier. Regarding your initial question about Intel’s plans to support MLO (Multi-Link Operation), I don’t have specific details about upcoming support or plans at the moment.
I’ve read your initial questions, but I didn’t catch the exact make and model of your router, as some of the text is in Korean. Could you please share the exact make and model of your router so I can proceed with further checking?
Von M.
VonM_Intel
Hello Eliot_C,
Von M.
Eliot_C
(2/5 reply)
VonM_Intel
Hello Eliot_C,
Thank you for confirming your laptop model (Lenovo ThinkPad P1 Gen7) and that you're using the preinstalled WiFi card. To proceed with further troubleshooting, could you please share the exact make and model of your router? This information will help me investigate the issue more effectively. I noticed that the model you mentioned above is the laptop model name not the router.
Von M.
VonM_Intel
Hello Eliot_C,
Von M.
Eliot_C
Sorry for my late response.
Here is TPlink model #. BE805
I already verified that other STA model MLO is working well with the router.
Eliot
VonM_Intel
Hello Eliot_C,
I appreciate you providing the TP-Link model number (BE805). It's good to know that the other STA model MLO is working well with the router. I see your question and I'll get back to you as soon as possible.
Von M.
VonM_Intel
Hello Eliot_C,
Thank you for your patience. Upon reviewing your Intel SSU reports, I noticed that your current OS, Windows 11 Pro Build 22631, does not meet the Wi-Fi 7 features. These features are available starting with Windows 11 version 24H2. At this time, I highly recommend checking with your OEM hardware provider.
Also, please be guided that I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
Eliot_C
So Intel SDK already support WIFI7 MLO feature.
But it depends on OEM as they need to mitigate it into their product.
I see.
Thanks for your help. will check with the OEM.
Eliot
