Wireless
8610 Discussions
Wifi Drop/slow conn. | MSI GF65 Thin 10ser | Intel WiFi 6 AX201 14.3 | Ubuntu 20.04.2
JulioLT
Hi there!
I have been struggling with wifi problems in the past 2 months. I did a fresh Kubuntu install on a brand new MSI laptop (GF65 Thin 10ser 884xes 15.6''), the `lsb_release -a` gives back:
[CODE]
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.2 LTS
Release:        20.04
Codename:       focal
[/CODE]
The symptoms are:
- I boot up the device, `NetworkManager` launches correctly and I can connect to my WiFi connection (both 2.4 and 5GHz, visible networks with WPA/WPA2 Personal secured)
- Randomly, webpages start to freeze or completely prevent to being loaded either with Firefox 87.0 or Chrome 89.0.4389.90. Maybe it is a new google search being loaded forever or a refresh page in Jira/Github
I have checked my router configuration and channels, which seems ok as the rest of devices and laptop can connect smoothly. Even I my previous laptop (which was another MSI), with the very same router and Wifi connections, worked perfectly well. So I end up thinking about drivers or some specific problem in the new MSI.
Some more information:
[CODE]
dmesg | grep iwlwifi
[    3.354582] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.376121] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 58.3.35.22
[    3.376123] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[    3.376124] iwlwifi 0000:00:14.3: Found debug configuration: 0
[    3.376322] iwlwifi 0000:00:14.3: loaded firmware version 50.3e391d3e.0 op_mode iwlmvm
[    3.395971] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[    3.407249] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[    3.407651] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[    3.559420] iwlwifi 0000:00:14.3: base HW address: 90:cc:df:f7:d2:4e
[    3.572863] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[    4.679607] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[    4.826374] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
[ 1080.953902] iwlwifi 0000:00:14.3: reached 10 old SN frames from f4:69:42:40:ef:ef on queue 7, stopping BA session on TID 1
[ 1341.941682] iwlwifi 0000:00:14.3: reached 10 old SN frames from f4:69:42:40:ef:ef on queue 8, stopping BA session on TID 1
[ 1733.836242] iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
[ 1760.519551] iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
[ 1761.498167] iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
[ 1844.453065] iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
[ 2044.202728] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 2044.259979] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[ 2063.668064] iwlwifi 0000:00:14.3: reached 10 old SN frames from f4:69:42:40:ef:ef on queue 8, stopping BA session on TID 0
[/CODE]
[CODE]
lsmod | grep iwl
iwlmvm                380928  0
mac80211              847872  1 iwlmvm
iwlwifi               331776  1 iwlmvm
cfg80211              704512  3 iwlmvm,iwlwifi,mac80211
[/CODE]
[CODE]
iwconfig
wlo1      IEEE 802.11  ESSID:"XXXX"
          Mode:Managed  Frequency:2.462 GHz  Access Point: XXX
          Bit Rate=144.4 Mb/s   Tx-Power=22 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=56/70  Signal level=-54 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:14   Missed beacon:0
[/CODE]
[CODE]
lshw -C network
WARNING: you should run this program as super-user.
  *-network
       description: Wireless interface
       product: Wi-Fi 6 AX201
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       logical name: wlo1
       version: 00
       serial: XX
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.4.0-70-generic firmware=50.3e391d3e.0 ip=192.168.1.69 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:16 memory:c5414000-c5417fff
[/CODE]
I have already tried some solutions I found on the Internet/Intel forums but with no luck at all. As you can see, I have the `power management` of the card set to off. I have also tried seting the wireless connection to hidden, fixed IPs, requiring `IPv4` for the current connection (2.4GHz) and some other more.
Of course, there is no problem if I connect through Ethernet but that solution is not possible in my actual office.
Can anyone help me with the issue?
Thank you!
Julio
Victor_G_Intel
Hello JulioLT,
To better assist you please provide the following report and information to continue.
Intel® System Support Utility (Intel® SSU)
Download link: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System
Instructions:
https://downloadmirror.intel.com/26735/eng/ReleaseNotes.txt
  1. Have you checked if this issue happens on different networks and different bands?
  2. Is this the original adapter that came pre-installed in your system?
  3. Are you currently using the correct kernel and firmware combination for the adapter?https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html
  4. Have you replicated this issue in Windows?
  5. Did you make sure Ubuntu was a compatible OS for the laptop by contacting MSI directly?
I look forward to hearing from you.
Victor G.
JulioLT
Hi Victor:
I have executed the script, although it said that it is not compatible with Ubuntu 20.04. The output is very similar from what I have already provided:
# SSU Scan Information
Scan Info:
     Version:"1.0.0.0"
     Scan Date:"2021/04/07"
     Scan Time:"08:55:18"
## Scanned Hardware
Computer:
          BaseBoard Manufacturer:"Micro-Star International Co., Ltd."
          Bios Mode:"UEFI"
          Bios Version/Date:"E16W1IMS.50B,05/19/2020"
          CD or DVD:"Not Available"
          Platform Role:"Linux julio-GF65-Thin-10SER 5.4.0-70-generic #78-Ubuntu SMP Fri Mar 19 13:29:52 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux"
          Processor:"Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz"
          Serial Number:"9S716W112884ZKB000126"
          SMBIOS Version:"3.2.0"
          Sound Cards:"HDA-Intel - HDA Intel PCH"
          Sound Cards:"HDA Intel PCH at 0xc5410000 irq 160"
          Sound Cards:"HDA-Intel - HDA NVidia"
          Sound Cards:"HDA NVidia at 0xc5080000 irq 17"
          System Manufacturer:"Micro-Star International Co., Ltd."
          System Model:"GF65 Thin 10SER"
          System Type:"x64-based PC"
          - Display
               - "Intel Corporation UHD Graphics (rev 05) (prog-if 00 [VGA controller])"
                    Adapter RAM:"size=256M"
                    Capabilities:"[40] Vendor Specific Information: Len=0c <?>"
                    Capabilities:"[70] Express Root Complex Integrated Endpoint, MSI 00"
                    Capabilities:"[ac] MSI: Enable+ Count=1/1 Maskable- 64bit-"
                    Capabilities:"[d0] Power Management version 2"
                    Capabilities:"[100] Process Address Space ID (PASID)"
                    Capabilities:"[200] Address Translation Service (ATS)"
                    Capabilities:"[300] Page Request Interface (PRI)"
                    Caption:"Intel Corporation UHD Graphics (rev 05) (prog-if 00 [VGA controller])"
                    Device ID:"MSI" Device
                    Driver:"i915"
                    Driver Path:"/lib/modules/5.4.0-70-generic/kernel/drivers/gpu/drm/i915/i915.ko"
                    Driver Provider:"Intel Corporation"
                    Driver Provider:"Tungsten Graphics, Inc."
                    Driver Version:""
                    Flags:"bus master, fast devsel, latency 0, IRQ 130"
                    Flags:"bus master, fast devsel, latency 0, IRQ 161"
                    I/O Ports:"I/O ports at 5000 [size=64]"
                    I/O Ports:"I/O ports at 4000 [size=128]"
                    Manufacturer:"NVIDIA Corporation [10DE]"
                    Manufacturer:"Intel Corporation [8086]"
                    Power Management Capabilities:"Power Management version 2"
                    Refresh Rate - Current:"60.00  60.00    59.94    50.00  "
                    Refresh Rate - Current:"144.00  59.97    59.96    60.00    59.93  "
                    Resolution:"1920x1080  60.00    59.94    50.00  "
                    Resolution:"1920x1080  59.97    59.96    60.00    59.93  "
               - "NVIDIA Corporation TU106 [GeForce RTX 2060] (rev a1) (prog-if 00 [VGA controller])"
                    Adapter RAM:"size=32M"
                    Capabilities:"[60] Power Management version 3"
                    Capabilities:"[68] MSI: Enable+ Count=1/1 Maskable- 64bit+"
                    Capabilities:"[78] Express Legacy Endpoint, MSI 00"
                    Capabilities:"[100] Virtual Channel"
                    Capabilities:"[250] Latency Tolerance Reporting"
                    Capabilities:"[258] L1 PM Substates"
                    Capabilities:"[128] Power Budgeting <?>"
                    Capabilities:"[420] Advanced Error Reporting"
                    Capabilities:"[600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>"
                    Capabilities:"[900] Secondary PCI Express"
                    Capabilities:"[bb0] Resizable BAR <?>"
                    Caption:"NVIDIA Corporation TU106 [GeForce RTX 2060] (rev a1) (prog-if 00 [VGA controller])"
                    Driver:"i915"
                    Driver Version:""
                    Power Management Capabilities:"Power Management version 3"
          - Memory
               Physical Memory (Available):"12603 MB"
               Physical Memory (Installed):"15827 MB"
               Physical Memory (Total):"17875 MB"
               - "ChannelA-DIMM0"
                    Capacity:"8192 MB"
                    Configured Clock Speed:"Not Available"
                    Configured Voltage:"1.2 V"
                    Data Width:"64 bits"
                    Form Factor:"SODIMM"
                    Interleave Position:"First Position"
                    Locator:"ChannelA-DIMM0"
                    Manufacturer:"830B"
                    Maximum Voltage:"1.2 V"
                    Minimum Voltage:"1.2 V"
                    Part Number:"T8GA64D88CX3S-JR"
                    Serial Number:"00155924"
                    Type:"Synchronous"
               - "ChannelB-DIMM0"
                    Capacity:"8192 MB"
                    Locator:"ChannelB-DIMM0"
                    Manufacturer:"830B"
                    Serial Number:"001527B4"
                    Type:"Synchronous"
          - Motherboard
               Product:"MS-16W1"
               Serial Number:"BSS-0123456789"
               Version:"REV"
          - Networking
               Interface br-4280cb8f4654:"Not Available"
               Interface br-510676a3d132:"Not Available"
               Interface br-53cc24c0c83d:"Not Available"
               Interface br-8154fe378ebc:"Not Available"
               Interface br-97e2bad4c7d9:"Not Available"
               Interface br-d6c2718da700:"Not Available"
               Interface br-ed07fbcaf78e:"Not Available"
               Interface docker0:"Not Available"
               Interface enp3s0:"Not Available"
               Interface wlo1:"Not Available"
          - Operating System
               Boot Device:"/dev/nvme0n1p5"
               Last Reset:"up 8 min"
               Locale:"en_US"
               OS Manufacturer:"Ubuntu 20.04.2 LTS \n \l"
               OS Name:"Ubuntu 20.04.2 LTS \n \l"
               Page File:"/swapfile"
               Page File Space (Available):"2097148"
               Page File Space (Used):"0"
               Physical Memory (Available):"12530 MB"
               Version:"5.4.0-70-generic GNU/Linux"
               Virtual Memory (Available):"2097148"
               Virtual Memory (Total):"16207492"
          - Processor
               - "Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz"
                    Architecture:"x86_64"
                    Available:"Offline"
                    Byte Order:"Little Endian"
                    Cache Size:"12288 KB"
                    Caption:"Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz"
                    - Characteristics
                         64-bit capable
                         Enhanced Virtualization
                         Execute Protection
                         Hardware Thread
                         Multi-Core
                         Power/Performance Control
                    CPU Speed (Minimum):"1905.733"
                    CPU Speed (Maximum):"8300 MHz"
                    Current Voltage:"0.8 V"
                    External Clock:"100 MHz"
                    Family:"Core i7"
                    - Flags
                         "ACPI (ACPI supported)"
                         "APIC (On-chip APIC hardware supported)"
                         "CLFSH (CLFLUSH instruction supported)"
                         "CMOV (Conditional move instruction supported)"
                         "CX8 (CMPXCHG8 instruction supported)"
                         "DE (Debugging extension)"
                         "DS (Debug store)"
                         "FPU (Floating-point unit on-chip)"
                         "FXSR (FXSAVE and FXSTOR instructions supported)"
                         "HTT (Multi-threading)"
                         "MCA (Machine check architecture)"
                         "MCE (Machine check exception)"
                         "MMX (MMX technology supported)"
                         "MSR (Model specific registers)"
                         "MTRR (Memory type range registers)"
                         "PAE (Physical address extension)"
                         "PAT (Page attribute table)"
                         "PBE (Pending break enabled)"
                         "PGE (Page global enable)"
                         "PSE-36 (36-bit page size extension)"
                         "PSE (Page size extension)"
                         "SEP (Fast system call)"
                         "SSE2 (Streaming SIMD extensions 2)"
                         "SSE (Streaming SIMD extensions)"
                         "SS (Self-snoop)"
                         "TM (Thermal monitor supported)"
                         "TSC (Time stamp counter)"
                         "VME (Virtual mode extension)"
                    ID:"52 06 0A 00 FF FB EB BF"
                    Level 1 Cache:"192 KiB
fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp pku ospke md_clear flush_l1d arch_capabilities"
                    Level 2 Cache:"1,5 MiB"
                    Level 3 Cache:"12 MiB"
                    Load:"load average: 0,32, 0,46, 0,27"
                    Manufacturer:"Intel(R) Corporation"
                    Model:"165"
                    Name:"Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz"
                    Number of Cores:"6"
                    Number of Cores - Enabled:"6"
                    Part Number:"To Be Filled By O.E.M."
                    Socket Designation:"U3E1"
                    Status:"Populated, Enabled"
                    Version:"Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz"
                    Voltage:"0.8 V"
                    Virtualization:"Not Available"
          - Storage
I have tried to share connection with my smartphone. Same thing happens. Can't test further in this matter.
  1. Is this the original adapter that came pre-installed in your system?
Yes. The laptop is 2 month old.
  1. Are you currently using the correct kernel and firmware combination for the adapter?https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html
Don't know exactly how to check that. I have a fresh install of Kubuntu 20.04. As you can see above with `dmesg | grep iwlwifi` or `lshw -C network`, the configuration for the wireless adapter is:
Seems to be a generic version. Do you recommend to try `iwlwifi-Qu-48.13675109.0.tgz` which appears in the link you are referring to? My Linux version is that:
Linux version 5.4.0-70-generic (buildd@lcy01-amd64-004) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #78-Ubuntu SMP Fri Mar 19 13:29:52 UTC 2021
  1. Have you replicated this issue in Windows?
Impossible for me to install Windows on this computer. As I said, I have plenty of laptops with Windows 7/10, OSX or an old MSI and all of them work as expected with the same band/network.
  1. Did you make sure Ubuntu was a compatible OS for the laptop by contacting MSI directly?
No. I am supposing that a newer version of a MSI should work with latest firmware/software based in my previous experience with another MSI, which also have an Intel card.
Thank you!
Julio
EDIT: I have checked /lib/firmware and the correct files are there since installation:
▶ l /lib/firmware | grep iwlwifi-Qu
-rw-r--r--   1 root  root   1,1M mar  2 20:55 iwlwifi-Qu-b0-hr-b0-48.ucode
-rw-r--r--   1 root  root   1,2M mar  2 20:55 iwlwifi-Qu-b0-hr-b0-55.ucode
-rw-r--r--   1 root  root   1,1M mar  2 20:55 iwlwifi-Qu-b0-jf-b0-48.ucode
-rw-r--r--   1 root  root   1,2M mar  2 20:55 iwlwifi-Qu-b0-jf-b0-55.ucode
-rw-r--r--   1 root  root   1,1M mar  2 20:55 iwlwifi-Qu-c0-hr-b0-48.ucode
-rw-r--r--   1 root  root   1,2M mar  2 20:55 iwlwifi-Qu-c0-hr-b0-55.ucode
-rw-r--r--   1 root  root   1,1M mar  2 20:55 iwlwifi-Qu-c0-jf-b0-48.ucode
-rw-r--r--   1 root  root   1,2M mar  2 20:55 iwlwifi-Qu-c0-jf-b0-55.ucode
-rw-r--r--   1 root  root   1,1M mar  2 20:55 iwlwifi-QuZ-a0-hr-b0-48.ucode
-rw-r--r--   1 root  root   1,1M mar  2 20:55 iwlwifi-QuZ-a0-hr-b0-50.ucode
-rw-r--r--   1 root  root   1,2M mar  2 20:55 iwlwifi-QuZ-a0-hr-b0-55.ucode
-rw-r--r--   1 root  root   1,1M mar  2 20:55 iwlwifi-QuZ-a0-jf-b0-48.ucode
-rw-r--r--   1 root  root   1,2M mar  2 20:55 iwlwifi-QuZ-a0-jf-b0-55.ucode
Victor_G_Intel
Hello JulioLT,
Please follow the steps below and provide us with the outputs needed to continue.
1-Type the following command to the terminal: # lspci​ to verify that the Intel network controller ​it’s been identified.
Note: If the output doesn't appear, then the system does not identify the Intel network adapter, and you will need to make sure it's properly integrated.
2-Type the following command to the terminal: # modinfo iwlwifi and let us know if you got an output.
Note: If there is no output, then the module isn’t installed, this will be a distribution installation issue.
3-Please type: # lsmod | grep iwlwifi and let us know if you got an output.
Note: If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
To verify, Please type: # dmesg | grep iwlwifi
Note: If the result is empty, the driver wasn’t initialized, and this is a distribution issue. If the result is populated proceed with the next step.
4-Check whether the suitable firmware is installed:
Please type: # dmesg | grep “no suitable firmware found!”​
Notes:
If none of the above steps help you determined what could be the source of the issue, please provide the following output along with a list of detailed steps in order to replicate your issue on our end:
Please type: # dmesg | grep ASSERT​
Notes:
Victor G.
JulioLT
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 02)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 05)
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
00:14.3 Network controller: Intel Corporation Wi-Fi 6 AX201
00:15.0 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
00:15.2 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #2
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1d.4 PCI bridge: Intel Corporation Device 06b4 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake LPC Controller
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH SPI Controller
01:00.0 VGA compatible controller: NVIDIA Corporation TU106 [GeForce RTX 2060] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
01:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1)
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
02:00.0 Non-Volatile memory controller: Sandisk Corp Device 5009 (rev 01)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Seems OK.
filename:       /lib/modules/5.4.0-70-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
author:         Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-ty-a0-gf-a0-50.ucode
firmware:       iwlwifi-so-a0-gf-a0-50.ucode
firmware:       iwlwifi-so-a0-hr-b0-50.ucode
firmware:       iwlwifi-so-a0-jf-b0-50.ucode
firmware:       iwlwifi-cc-a0-50.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-50.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-50.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-50.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-50.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-50.ucode
firmware:       iwlwifi-QuQnj-a0-hr-a0-50.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-50.ucode
firmware:       iwlwifi-QuQnj-f0-hr-a0-50.ucode
firmware:       iwlwifi-Qu-a0-jf-b0-50.ucode
firmware:       iwlwifi-Qu-a0-hr-a0-50.ucode
srcversion:     4359D848BB9C2EA0A0A1463
alias:          pci:v00008086d00007AF0sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd00000090bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd00000090bc*sc*i*
alias:          pci:v00008086d00002725sv*sd000000B0bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000024bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000020bc*sc*i*
alias:          pci:v00008086d00002725sv*sd00000090bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00004088bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00004080bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00002080bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00001654bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00001653bc*sc*i*
alias:          pci:v00008086d00002723sv*sd0000008Cbc*sc*i*
alias:          pci:v00008086d00002723sv*sd00000088bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00000084bc*sc*i*
alias:          pci:v00008086d00002723sv*sd00000080bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000044bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004244bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00002074bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001652bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001651bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001080bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000244bc*sc*i*
alias:          pci:v00008086d00002720sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000078bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000074bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000070bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000044bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000040bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004244bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004070bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00002074bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001652bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001651bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000244bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd0000007Cbc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000078bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000074bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000070bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00004234bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00004034bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00004030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00002034bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00002030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001552bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001551bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001210bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001030bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000264bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000260bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000238bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000234bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000230bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000064bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000060bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000038bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000034bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd00000030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002A10bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00002010bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001210bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00001010bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000A10bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000710bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000610bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000510bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000410bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000310bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000210bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000010bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00004234bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00004034bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00004030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00002034bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00002030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001552bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001551bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001210bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001030bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000264bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000260bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000238bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000234bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000230bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000064bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000060bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000038bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000034bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd00000030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00004234bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00004034bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00004030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00002034bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00002030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001552bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001551bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001210bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001030bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000264bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000260bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000238bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000234bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000230bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000064bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000060bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000038bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000034bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd00000030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00002720sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00002720sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00002720sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00002720sv*sd00000034bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd00000214bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000214bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000210bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000014bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd00000010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000E014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000E010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000A014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00008014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00006014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00006010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004234bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004034bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000401Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004018bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00004010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00002034bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00002030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001610bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001552bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001551bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001550bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001420bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001410bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001210bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00001010bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000264bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000260bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000238bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000234bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000230bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000214bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000210bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d00002526sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000064bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000060bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000038bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000034bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000030bc*sc*i*
alias:          pci:v00008086d00002526sv*sd0000001Cbc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000018bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000014bc*sc*i*
alias:          pci:v00008086d00002526sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000042A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004234bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000040A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004034bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00004030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00002034bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00002030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001552bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001551bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000002A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000002A0bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000264bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000260bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd0000023Cbc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000238bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000234bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000230bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000000A4bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd000000A0bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000064bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd0000003Cbc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000038bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000034bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211
retpoline:      Y
intree:         Y
vermagic:       5.4.0-70-generic SMP mod_unload modversions
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        62:31:DF:89:D9:4A:2B:CB:A8:66:B6:24:C3:86:03:D5:FB:D0:21:C2
sig_hashalgo:   sha512
signature:      4F:76:B7:5E:10:8A:32:84:E6:6E:5F:DA:40:B9:C3:23:23:DE:47:BA:
                EE:83:FC:65:A4:C8:B7:B7:A5:01:F1:A8:E3:76:1D:0C:A1:2A:41:1E:
                14:97:04:72:CC:76:45:29:ED:7B:03:11:A2:D5:50:2D:EA:86:3E:EF:
                71:87:63:AB:C3:D3:7E:AF:2C:C3:8F:A2:D6:57:59:F5:52:2E:72:1F:
                86:2A:B3:1E:07:36:A7:0B:6B:EB:0C:FE:26:B9:92:36:63:4F:99:01:
                A7:25:66:B4:3C:51:43:01:5D:B6:F2:BA:D1:0A:11:B0:DE:C2:3D:87:
                8B:D4:97:9A:52:FF:82:B9:FA:89:9E:C3:5F:6A:69:41:75:7B:1E:D3:
                68:AD:F1:D9:16:A6:D0:13:D8:0F:3F:28:75:B5:AE:C9:E6:6A:0A:3F:
                A7:D1:F4:99:7C:3C:FB:83:A5:69:4B:6B:B0:9E:BC:FF:B7:3D:39:24:
                C8:C9:6C:30:3F:19:98:BE:E2:8D:A6:44:9D:62:F2:48:07:B1:AA:21:
                B9:8D:59:05:D6:79:DF:BC:9E:46:50:EB:A5:59:92:A8:CE:39:FA:18:
                4F:D4:16:94:D1:16:66:2E:27:BD:46:7D:71:65:0A:5E:29:C7:86:15:
                EB:00:13:D3:72:A7:06:DC:1E:A4:EB:CD:ED:32:F9:34:21:61:CA:C2:
                12:DC:B4:53:87:3B:67:5E:C2:66:4E:C7:FE:B5:A7:10:CA:E2:D3:A6:
                54:47:87:2B:99:73:5F:E9:77:27:1E:05:1D:FA:3C:BD:79:67:9C:CD:
                6F:14:70:A0:65:80:09:FA:90:36:06:53:5D:0B:89:9D:64:95:4F:17:
                16:CC:87:5F:92:09:2C:F7:C1:E7:A8:AC:B3:F0:08:8D:54:BA:89:8B:
                E2:9A:30:80:A7:32:4B:DC:61:6B:3E:6C:A9:F6:CA:C6:4D:61:EE:3D:
                E9:A1:71:0E:3D:65:CB:8D:EB:C0:4D:3E:1A:72:BE:29:C2:20:F6:A6:
                FC:BD:8E:BE:63:EE:94:E7:D6:BB:C9:7E:82:6F:48:FF:D5:5F:CA:99:
                78:96:0D:57:D4:6D:32:F8:8D:8B:29:63:1B:CD:B9:31:4F:FE:F8:48:
                02:29:E8:AC:9F:26:C7:55:11:3A:CC:CC:D6:8D:80:07:3B:E9:6C:6D:
                E9:25:55:97:56:AF:CD:39:0C:21:30:5C:D2:E4:EC:41:34:FA:F2:D2:
                20:E3:BD:8F:8E:CF:C5:7A:B9:6F:FA:51:28:2A:56:4A:39:B3:17:D0:
                CD:66:7A:DD:96:CE:84:F5:77:4A:EB:8A:2F:A4:1E:BD:D1:55:33:04:
                FC:EB:5E:D1:9E:7D:17:1F:D9:D8:2C:1E
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           antenna_coupling:specify antenna coupling in dB (default: 0 dB) (int)
parm:           nvm_file:NVM file name (charp)
parm:           lar_disable:disable LAR functionality (default: N) (bool)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:Enable debug INI TLV FW debug infrastructure (default: 0 (bool)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
Seems OK.
Already done but again:
▶ dmesg | grep iwlwifi
[    3.267853] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.272809] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 58.3.35.22
[    3.272815] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[    3.272817] iwlwifi 0000:00:14.3: Found debug configuration: 0
[    3.273191] iwlwifi 0000:00:14.3: loaded firmware version 50.3e391d3e.0 op_mode iwlmvm
[    3.314666] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[    3.322672] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[    3.323637] iwlwifi 0000:00:14.3: Allocated 0x00400000 bytes for firmware monitor.
[    3.475430] iwlwifi 0000:00:14.3: base HW address: 90:cc:df:f7:d2:4e
[    3.489891] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[  339.447218] iwlwifi 0000:00:14.3: Applying debug destination EXTERNAL_DRAM
[  339.595205] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
Seems OK.
4-Check whether the suitable firmware is installed: Please type: # dmesg | grep “no suitable firmware found!”​
Result is empty.
▶ dmesg | grep "no suitable firmware found"
There is nothing else I could clarify. The issue is really chaotic as there are like 2-3 hours that the WiFi could work as expected and then, no more than 5 minutes.
The output is empty.
I have read the resource (https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging) and I plan to execute:
sudo trace-cmd record -e iwlwifi -e mac80211 -e cfg80211 -e iwlwifi_msg
whenever I detect an episode of failing connection after each 5 minutes. Then I will attach the `trace.dat`.
JulioLT
No so long to the bug to appear. Here are some things.
- I have attached a tiny video.
- A trace during that tests (first 10-15 minutes), then I switch to ethernet
Hope this would help, somehow.
Julio
Victor_G_Intel
Hello JulioLT,
We appreciate the information provided and the logs, and we will use them to investigate this issue further on our end, please wait for our response we will update the thread as soon as possible.
Victor G.
Victor_G_Intel
Hello JulioLT,
To continue with our investigation can you please provide the following information:
1) May we know how many systems in your company 'circury.com' are impacted by this slow/drop connection issue?
2)In your dmesg logs appear three messages that may affect the wireless connection:
Message#1.[ 1080.953902] iwlwifi 0000:00:14.3: reached 10 old SN frames from f4:69:42:40:ef:ef on queue 7, stopping BA session on TID
Message#2. [ 1733.836242] iwlwifi 0000:00:14.3: No beacon heard and the time event is over already...
Message#3. [ 2044.202728] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
Can you complete an upgrade to the Linux Kernel from version 5.4 to the latest (e.g. 5.10 or 5.11) to obtain the latest Intel wireless FW 59?
3) After upgrading to the latest wireless FW 59, if the WiFi drop/slow connection still occurs, please provide the complete dmesg: Type # dmesg > dmesg.log in a .txt file.
I look forward to hearing from you.
Victor G.
JulioLT
Hi there! Didn't see the old e-mail warning in my box. Thanks for answering.
1) I haven't asked everyone but I could hear from two more person with a bit older MSI's laptop too.
2) I will try to upgrade to 5.11 in the next few days.
3) Then, I will check the wireless version and if the issue still remains.
Talk to you soon.
Alberto_Sykes
Hello JulioLT, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
JulioLT
Updated kernel to `5.11` and the firmware being loaded is now (just after reboot):
▶ sudo dmesg | grep iwlwifi
[    3.331708] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.335181] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-59.ucode failed with error -2
[    3.335561] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-58.ucode failed with error -2
[    3.335725] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-57.ucode failed with error -2
[    3.335739] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-56.ucode failed with error -2
[    3.337149] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    3.337161] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 65.3.35.22
[    3.337164] iwlwifi 0000:00:14.3: Found debug destination: EXTERNAL_DRAM
[    3.337166] iwlwifi 0000:00:14.3: Found debug configuration: 0
[    3.337354] iwlwifi 0000:00:14.3: loaded firmware version 55.d9698065.0 QuZ-a0-hr-b0-55.ucode op_mode iwlmvm
[    3.395804] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[    3.576505] iwlwifi 0000:00:14.3: base HW address: 90:cc:df:f7:d2:4e
[    3.590568] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
▶ uname -sr
Linux 5.11.0-051100-generic
I will keep an eye just in case the issue appears again.
Victor_G_Intel
Hello JulioLT,
Please feel free to test it out for a few days and let us know if the issue persists.
Victor G.
Victor_G_Intel
Hello JulioLT,
Please let me know if you need further assistance.
Victor G.
JulioLT
Hi Victor:
I did check your answer and I'm testing the laptop these few days. The issues is still there but it occurs less than before the kernel update, certainly. The connection is reset when trying to Share Screen on Zoom/Google Meet/Teams.
I suppose that the WiFi card maybe is not right after all. Even in 50 cm of the router, the issue won't disappear.
I don't know if you have any other suggestion.
Victor_G_Intel
Hello JulioLT,
Thank you for your response.
Please provide the complete dmesg: Type # dmesg > dmesg.log in a .txt file so we can continue
checking this issue internally.
Victor G.
Victor_G_Intel
Hello JulioLT,
Victor G.
JulioLT
Hi Victor,
Thanks for the heads up, I didn't notice. Please, find attached a `dmesg.log` file from my recent laptop's boot up.
DeividA_Intel
Hello JulioLT,
Thanks for the information provided, with this we will be able to continue with the research. I will post back with more details as soon as we have them.
Deivid A.
JulioLT
Hi there,
Still having the same issues and these days is getting worse, I don't know exactly why...
DeividA_Intel
Hello JulioLT,
Based on the research, I would like to inform you of the following:
1) The latest dmesg log shows the wireless doesn't successfully load to the latest firmware 59, please try to fix it and have wireless load the iwlwifi-QuZ-a0-hr-b0-59.ucode
[ 3.158410] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-59.ucode failed with error -2
[ 3.161513] iwlwifi 0000:00:14.3: loaded firmware version 55.d9698065.0 QuZ-a0-hr-b0-55.ucode op_mode iwlmvm
2) With Kernel 5.11, you are still able to load a newer firmware 55 and the log shows different messages compared with the previous Kernel 5.4. The log now indicates the wireless could successfully connect to the AP and is disassociated because the client is leaving the AP (i.e. Reason 8=DISASSOC_STA_HAS_LEFT)
[ 64.414530] wlo1: associated
[ 64.529590] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 67.420178] wlo1: deauthenticated from xx:xx:xx:xx:xx:xx (Reason: 8=DISASSOC_STA_HAS_LEFT)
If Reason 8=DISASSOC_STA_HAS_LEFT occurs often, we suggest checking and optimize the wireless AP settings. Try not to use the same SSID on 2.4 GHz and 5 GHz bands. Instead of setting the AP channel at 'Auto', set it at a fixed channel that is not congested.
Also, try to connect to the AP in 5 GHz because it's less crowded than 2.4 GHz.
Deivid A.
JulioLT
Hey Deivid,
Thank you for your comment. I am still experiencing issues with WiFi during all this time.
Based in your comment, I have copied the QuZ-a0-hr-b0-59.ucode from the git repo to my /lib/firmware folder. Now I can see the 59 version being loaded at boot time:
[    3.369767] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.374048] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    3.374057] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 65.3.35.22
[    3.374246] iwlwifi 0000:00:14.3: loaded firmware version 59.601f3a66.0 QuZ-a0-hr-b0-59.ucode op_mode iwlmvm
[    3.435452] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[    3.633424] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
I had (and I have still) a different SSID for 2.4/5 WiFi bands, as well as 2.4 being configured to a fixed channel where I find less collides between neighbors-connections.
Hope this would fix the issue. I will post again in a few days.
