Wireless
8510 Discussions
Wifi adapter (Intel AC 3165) does not work after automatic windows update
TotalmenteDesesperado
I have been having this recurring problem for over 2 years: every 2-3 months and sometimes within days, after an automatic Windows update, my bluetooth and wifi connections stop working. I somehow manage to fix it after 2-3 days of trying different solutions but none of them seems to be THE ONE, as most of the times it just miraculously starts working as I turn the computer on. I have found the following post that perfectly describes what is happening to me, but none of the solutions are working for me: https://www.intel.com/content/www/us/en/support/articles/000031150/wireless/wireless-software.html
My portable computer is a Dell Inspiron 5570. The error I detect in the Device Manager is that the network adapter "Intel(R) Dual Band Wireless-AC 3165 #2" appears hidden from me. When I look at properties, it says that the hardware device is not connected to the computer (error Code 45). Whenever I search for the most updated driver, it says that I am already using the latest.
Please, I need serious help as I have been forced to reset my computer to factory settings several times, losing many valuable information. I would like to receive 2 kind of solutions: one to make my wifi adapter work correctly again and another to prevent this from happening in the future.
Thank you very much for your help
AlHill
Roll back the bad driver in the device manager.
Reboot.
Then, run the Microsoft wuShowHide tool (attached) and block/hide the offending Microsoft update.
Thank you, but the option of rolling back the driver in the device manager cannot be pressed as it is kind of greyish and not available
n_scott_pearson
Actually, you need to do a clean install in order to get back to the proper version. Here is my process for doing so:
  1. If you haven't already, download to your PC - but do not install just yet - the Bluetooth and Wireless driver packages for your adapter. Here are the current links for downloading these drivers: Wireless: https://www.intel.com/content/www/us/en/download/19351 and Bluetooth: https://www.intel.com/content/www/us/en/download/18649.
  2. Most important! Disable Internet access. Unplug Ethernet cable and/or disable wireless. Keep disabled until told to re-enable. Note this Wireless disable *must* be of type that will persist (stay disabled) across reboots.
  3. From the Apps & Features applet, check for instances of Intel PROSet/Wireless Software and Intel Wireless Bluetooth. If none, skip to Step 6.
  4. Uninstall each instance of Intel PROSet/Wireless Software and/or Intel Wireless Bluetooth that is present. When prompted, choose "Discard Settings".
  5. Manually reboot your computer, keeping Internet access disabled throughout.
  6. From the Device Manager applet, check the Network Adapters section for an entry for Intel Dual Band Wireless-AC 3165 and check the Bluetooth section for an entry for Intel Wireless Bluetooth that has an intel driver associated with it. If neither is the case, go forward to Step 10.
  7. Right click on the entry for Intel Dual Band Wireless-AC 3165 and uninstall it, choosing (checkmark) Delete the driver software for this device.
  8. Right click on the entry for Intel Wireless Bluetooth and open its properties. If it has an Intel driver associated with it, then uninstall it, choosing to (checkmark) Delete the driver software for this device.
  9. Go back to Step 5.
  10. Install the downloaded Bluetooth driver package (my rule: always install Bluetooth first).
  11. Install the downloaded Wireless driver package.
  12. Manually shutdown and reboot your computer.
  13. Reenable Internet access. Restore Ethernet cable and/or reenable wireless.
  14. Test.
Note that it sometimes takes multiple uninstalls (and reboots) to clean out the old installations, so don't give up on the process until you hit, say, 10 reboots.
Ok, once this is complete and you are in a working state, you need to run the WUShowHide troubleshooter (Al provided link for this above) and block any subsequent releases from installing. I recommend that you NOT use Intel's Driver & Support Assistant (DSA); use Dell's instead.
Hope this helps,
Hi n_scott_pearson,
Thanks for your support. Once again, I'm not sure how, but today my connections suddenly returned to normal. I didn't do anything special—just left the computer stored and unplugged for the weekend. When I turned it on this morning, both Wi-Fi and Bluetooth were back in action. Any suggestions on how to prevent this from happening again? If you recommend installing WUShowHide, could you please provide specific instructions? I'm not familiar with that software.
Thanks a lot.
Robert-CH
Thanks for those very useful instructions. The link to the wireless drivers ending with "19351" now goes to a place where only variants of version 23 are available. Is there any way to get to an archive of old versions? I am actually trying to find version 18.12.1.2 of the 3165 drivers to install on a Lenovo E560 Thinkpad with Win7 64 for which that is the last supported version. Any advice you could give about finding this version anywhere at all would be very welcome. Thanks.
n_scott_pearson
I never asked you whether this was Windows 10 or Windows 11. In Windows 10, you have a window between when a driver is promoted for installation and its actual installation. Within this window, you can use the WUShowHide tool to hide these driver installations. In Windows 11, on the other hand, the Window for catching drivers is a lot smaller - and this may have been why the WUShowHide tool is not being promoted by Microsoft any longer (even if it was written by them).
WUShowHide runs as a Windows troubleshooter and walks you through the process. It can scan for driver installations that are pending or optional and allows you to then choose which to hide.
Hope this helps,
P.S. You can also download this tool from MS site: https://download.microsoft.com/download/f/2/2/f22d5fdb-59cd-4275-8c95-1be17bf70b21/wushowhide.diagcab.
n_scott_pearson
You are correct; my generalized instructions were for non-discontinued adapters, and thus only for the latest offered driver release(s). My records show that the final package releases that included drivers for the (now discontinued) 3165 were version 23.40.0.
You can download these driver packages from my OneDrive share. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access this share. Subfolder Wireless-AC 3165, 3168, 7265-D provides the final driver packages for the 3165
Hope this helps,
Robert-CH
Thanks for the information and for sharing your archive. Unfortunately the files in your archive appear to all be for Windows 10 and 11, and I am looking for 3165 drivers that run on a Lenovo E560 Thinkpad under Windows 7 64-bit. The last driver version supported by Lenovo is 18.12.1.2, which does not support 802.11ac on the 3165. I would like to somewhere find a later version which does support 802.11ac, try it out, and in the worst case be able to roll back to 18.12.1.2.  And I was hoping to somewhere find an archive of driver versions which would support this exercise. But so far I've found neither such an archive nor any tips about which later version of the 3165 driver would be a good one to try (i.e. supports 802.11ac and actually runs under Win7-64). Thanks anyway for your interest.
n_scott_pearson
Ok, I did some digging and was able to determine that the 21.50.5 Hotfix releases were the last package that Intel provided that included support for Windows 7. This was driver versions 20.90.6.5 for Bluetooth and 19.10.21.1 for Wireless. AFAIK, starting with the 21.50.0 release, Intel dropped Windows 7 support completely. This applies to the Wireless-AC 3165, 3168, 7265-D, 8260 and 8265.
I have updated my share with the pertinent Windows 7 files.
Hope this helps,
Robert-CH
Many thanks for your trouble. I have downloaded the Win7 files and plan to try the 19.10.21.1 wireless driver you found. The Lenovo System Update already upgraded the Bluetooth driver to 20.90.6.5 a few days ago, but it refuses to offer anything better than 18.12.1.2 for wireless. Should I be worried? If Lenovo approves the Bluetooth part of the 21.40.5 release but rejects the wireless part, maybe they know something I don't. In my shoes, would you give it a shot?
n_scott_pearson
You're incorrectly assuming that there were people sitting behind the steering wheels at all times.
I would go ahead and try them. If there's a problem, you can always uninstall and go back.
Robert-CH
Thanks. I've always been a bit naive like that [wink – why does this annoying editor remove emojis?]
