Wireless
8721 Discussions
No Killer adapters connected
RK2
On opening Killer Control center  application it detects the wifi but it doesn't show any current network traffic at all. The status says "No Killer Adapters Connected". I even have the latest killer wireless driver installed.
JosueO_Intel
Hello RK2,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Was it working before? If so, when did the issue start happening?
  2. Is this a desktop or a laptop?
  3. Is this the original adapter of the system?
  4. What is the model of the adapter you are using?
  5. Have you tried using the drivers provided by the OEM?
  6. Have you reported this issue to the OEM?
  7. Which driver version did you install?
  8. Screenshot of the issue.
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response.
Josue O.
OPERATOR
Hello I just Update my MSI Steel Series Laptops Killer Command Center and now my Killer network card ins not detected
I uninstalled it then Reinstalled it and the same thing Detection At all.
MSI GE63 Raider RGB gaming laptop with up to 9th gen Intel Core i9 processor and all new GeForce RTX 2060 graphics. GE63 Raider RGB
System Windows 11 Pro
32 Gb Ram
Nvidia RTX 2060 Gpu
2 TB SSD M2 Drivers
System Runs smooth No Issues at all Except your New Updated Interface doesn't Detect my Killer Network Card
and it did before the update.
 One thing i will say the new interface looks nice but it would be better if it worked
thank for the help
Maybe Release a Firmware Patch to fix it would be nice asap
JosueO_Intel
Hello RK2,
Josue O.
JosueO_Intel
Hello RK2,
Josue O.
