I have recently buy a new wifi card for my PC cause the current one is old and have somes problems but this new card isn't detected on my PC with Windows 10.
It's this : Cudy WE3000 Ax3000 Carte WiFi 6 PCIe, 2402Mbps + 574Mbps, AX200, OFDMA, Bluetooth 5.0/4.2/4.0, Windows 10
https://www.amazon.fr/dp/B082NZYDDM?ref=ppx_yo2ov_dt_b_fed_asin_title
I don't see it in the Device Manager, even when I try to see the invisible device.
I have install and uninstall this driver many times but it doesn't change https://www.intel.com/content/www/us/en/products/sku/204836/intel-wifi-6e-ax210-gig/downloads.html
I tried to put the card in the PCIe slot 1, 16 where my old Wifi card is detected but it doesn't work, .
I read on forums that the card may not work with certain motherboards maybe somone know more about that. Mine is Gigabyte GA-AB350-Gaming 3 Carte mère AMD B350 Socket AM4 https://www.amazon.fr/dp/B06XMYM95G?ref=ppx_yo2ov_dt_b_fed_asin_title
I don't know if someone have an idea so I'm waiting for your response, thank you.
PCIe WiFi card carrier devices such as this have problems if they are plugged into PCIe x4/x8/x16 slots. You should have it plugged into a PCIe x1 slot. Your motherboard only has one of these slots; I hope it is available.
Hope this helps,
I had tried in the two PCIe x1 (where my old card works) but it didn't work.
BUT in less than 24h my pc crashed 5-6 times and now the wifi card appears in the device manager (one time I get the error code 0xc0000225).
I don't know if I may be happy but I hope that my problem is solve (but not for a new one), thank you for your help
And in conclusion I don't know how I have solve it X)
