I have an asus fx506li computer that has windows 11 installed. For the past year or so the ax201 wifi driver installed on it has periodically stopped working. Recently it has stopped working much more frequently and I have manually installed newer versions of the driver which have also had the same problem.
Every time it fails the event that shows up says “device not started (netwtw 10)”.
What does device manager say in Network adapters- Advanced- Wireless mode- value ?
Cheers
3Fees
In 802. 11a/b/g wireless mode it says dual band 802.11a/b/g
In 802.11n/ac/ax wireless mode it says 802.11ax
Should be set to one or the other, the top one works for me. 802.11 a/b/g
Cheers
3Fees
Thanks for the suggestion, however it still isn’t working.
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
Topic Options
