Wireless
8554 Discussions
Wifi randomly disconnecting
Emmanuel7589
So this week i started my wifi started acting up i thought its on all devices but turns out its jusy my pc
i did everything i could forgetting the wifi, updated driver, reseting network adapter, uninstalling the driver, manually setting ip but didnt change a thing
the wifi just randomly disconnect and disappear, when it appear again it takes longer than it should to connect. Its so bad that i basically have few minutes sometimes seconds before it go away again|
like i said its only for this specific pc, and other wifi networks even in the same building work fine
https://streamable.com/2p4uxj
Mike_Intel
Hello Emmanuel7589,
  1. What is the model of the wireless controller?
  2. What is the brand and model of the system?
  3. Was it working fine before?
  4. What was the last change made before the issue started?
  5. What are the troubleshooting steps that you tried so far?
  6. For me to review the hardware and the installed driver, please help generate the SSU logs of the system. Kindly refer to the link below on how to generate the logs:
Michael L.
Emmanuel7589
1. Intel(R) Wi-Fi 6 AX201 160Mhz
2.Legion 5 15ITH6H
3.Yes
4.Im not sure
5.Manually changing ip which was mildly successful, updating driver,uninstalling driver, updating windows
Jtech254
I have the same issue on:
- Lenovo E14 Gen 6
- Intel (R) Wi-Fi 6 Ax201 160MHz ( I have updated the drivers to 23.160.0.4)
Below are some troubleshoot i have done
- Updated the drivers
- Set Roaming aggressiveness to Low and Medium
Any update on this will be appreciated
Emmanuel7589
Thanks for your answer
The issue is still there after following instructions
i think its mainly a issue with DHCP
when i connect to the wifi after restarting the issue is there but if i manually change ip i gain access to internet
instructions you provided made it that the network stopped disappearing
Mike_Intel
Hello Emmanuel7589,
Thank you for the update.
Kindly try to perform clean driver installation of the wireless driver and check if this one will help.
Clean Installation of Wireless Drivers
Intel® Wireless Wi-Fi Drivers for Windows® 10 and Windows 11*
@Jtech254
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Mike_Intel
Hello Emmanuel7589,
Michael L.
Emmanuel7589
sorry for the delay
the clean install fixed it
the wifi stopped disappearing and i dont need to change ip manually now
Thanks for you help
Mike_Intel
Hello Emmanuel7589,
Thank you for the update and I am glad that the issue is now fixed
Since your system is working fine now, I need to close this inquiry.
Michael L.
