Wireless
8666 Discussions
Windows 10 crashing on hibernate/restart/shutdown - blocked irp Advanced-n 6235
NWhym
I've recently upgraded by laptop (Dell XPS 15 L521X) and I'm now suffering hangs and crashes every time my PC tries hibernate, restart or shut down. This didn't happen on my previous OS (win7).
I got a mini dump and noticed that the problem appears to be in the driver for my wifi card an Intel Advanced-N 6235. The driver was old (also bluetooth appeared to be broken) so I installed the latest drivers directly from the Intel site - 15.8.0.1. Unfortunately this doesn't appear to have solved the issue and I'm still getting mini dumps produced.
Is there anything I can do other than wait for it to be fixed in later driver updates? Here's the info from the dump:
: kd> !Analyze -v
* Bugcheck Analysis *
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time (usually 10 minutes).
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: ffffe00050b59060, Physical Device Object of the stack
Arg3: ffffd001ee006990, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: ffffe00058bae480, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 55a5ba1c
MODULE_NAME: pci
FAULTING_MODULE: fffff80142c30000 pci
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
TAG_NOT_DEFINED_c000000f: FFFFD001EE00DFB0
STACK_TEXT:
ffffd001`ee006958 fffff802`ad02092e : 00000000`0000009f 00000000`00000003 ffffe000`50b59060 ffffd001`ee006990 : nt!KeBugCheckEx
ffffd001`ee006960 fffff802`ad02084e : ffffe000`54fd4420 ffffd001`ee006b58 00000000`00000000 00000000`00000005 : nt!PopIrpWatchdogBugcheck+0xde
ffffd001`ee0069c0 fffff802`ace4f21a : ffffe000`54fd4458 00000000`00000001 ffffd001`ee006b18 00000000`00000002 : nt!PopIrpWatchdog+0x32
ffffd001`ee006a10 fffff802`acf4ff7a : ffffd001`ee1c5180 ffffd001`ee1c5180 ffffd001`ee1d1cc0 ffffe000`570a4080 : nt!KiRetireDpcList+0x42a
ffffd001`ee006c60 00000000`00000000 : ffffd001`ee007000 ffffd001`ee001000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: 0x9F_3_NETwew01_IMAGE_pci.sys
Followup: MachineOwner
1: kd> !irp ffffe00058bae480
Irp is active with 5 stacks 3 is current (= 0xffffe00058bae5e0)
No Mdl: No System Buffer: Thread 00000000: Irp stack trace.
cmd flg cl Device File Completion-Context
[ 0, 0] 0 0 00000000 00000000 00000000-00000000
Args: 00000000 00000000 00000000 00000000
>[ 16, 2] 0 0 ffffe0005457b050 00000000 00000000-00000000
Unable to load image \SystemRoot\System32\drivers\NETwew01.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for NETwew01.sys
*** ERROR: Module load completed but symbols could not be loaded for NETwew01.sys
\Driver\NETwNe64
Args: 00015600 00000000 00000005 00000003
[ 16, 2] 0 e1 ffffe000545a4b00 00000000 fffff802ad1e2d40-ffffe00054fd4420 Success Error Cancel pending
\Driver\vwifibus nt!PopSystemIrpCompletion
[ 0, 0] 0 0 00000000 00000000 00000000-ffffe00054fd4420
NWhym
Just in case someone else has the same issue I installed the latest bios for my XPS15 (A16) and that seems to have fixed it
It did get a bit hairy, there was a windows update as well and the laptop decided to reboot itself during the bios install (wasn't sure whether it was caused by the bios installer or not). The I got boot device unrecognized lots of times which made me wonder if the bios update had failed. Thankfully after booting into safe mode (and doing nothing) I was able to boot normally. Wipes sweat from brow....
NWhym
