Wireless
9029 Discussions
Wireless-AC 9560 | Code 10 - this device cannot start
Elividon
The last three weeks I've had major issues with the Intel Wireless-AC 9560 on my MSI Creator P65 8RE. I bought it in April 2019.
Message in device manager:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
I've tried...
  • installing the newest drivers from Intel and MSI.
  • Resetting my BIOS.
  • Updating the BIOS.
  • And I just wiped my C: driver and reinstalled Windows 10.
The issue remains the same.
I attached the system information file to this post, created with the Intel System Support Utility.
Thank you in advance.
Steven_Intel
Hello Elividon,
Usually for code 10 error in device manager, we recommend the following steps:
Make sure to follow the steps in this article for each installation https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html
Steven G.
Elividon
Hello Steven,
Thanks for your reply. I tried the latest OEM driver from the MSI website, and I tried the Intel generic driver. Both with a cold reboot. And I followed all the steps here. https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html
The Wireless-AC 9560 still gives a code 10 error. Any other ideas?
Thanks!
Steven_Intel
Thank you for your response.
We are going to investigate this and let you know as soon as I have an update.
Steven G.
Steven_Intel
Hello Elividon,
Please try the following recommendations:
- Apply the recommended steps for 802.11ac standard: https://www.intel.com/content/www/us/en/support/articles/000024678.html
- Make sure the router or Access Point is well configured. You may need to contact your Internet Service Provider to ensure this.
Please let me know of the outcome.
Steven G.
Elividon
Hi Steven,
I check all the settings as recommended one by one. Everything was already configurated as documented in the article you sent me.
Surely the access point it not the problem. I've been at about 10 different locations throughout Norway and it all results in the Wireless AC-9560 not working.
Could there be a hardware issues resulting in a code 10?
Elividon
Steven_Intel
Steven G.
Steven_Intel
Hello Elividon,
It is possible there is a hardware issue, based on the troubleshooting steps performed so far. Nevertheless, I will research more and check if there is any other fix we can try.
Steven G.
Steven_Intel
Hello Elividon,
Based on the steps performed already, we recommend you to contact the Original Equipment Manufacturer (OEM), as it is possible there is a hardware issue.
Steven G.
Elividon
FYI. A couple of weeks ago I opened my laptop, took the Wi-Fi-adapter out and put it back in. Eversince the Wireless AC-9560 has been working properly.
