On my Dell Inspiron I have the Dell Wireless display working fine, close the app, then close the lid, reopen it a minute later, click on Intel Wireless Display icon and when the app opens it comes up with "Wireless Display Adapter not found".
The only way I can get it to work again is to reboot the computer..
What is the solution to this problem. Dell can't resolve it and referred me to Intel and I have found no way to directly contact Dell support on this issue. They don't accept emails on the Wireless Display Adapter.
Jensor
- Tags:
- Wireless Display
In device manager, network
Your wireless adapter, uncheck the box, allow the computer to turn off to save power.
Do NOT uncheck the boxes under Microsoft Virtual Miniport adapters.
Rick
In Device Manager I find:
Network Adapters, Intel(R) Centrino(R) Wireless-N1030, Properties, Power Management and find "Allow the computer to turn off power to this device" box is already unchecked.
So I'm still looking for a solution.
jensor
The boxes can be unchecked for all of them except...
Microsoft Virtual Miniport adapter# 2
The Microsoft Virtual miniport adapters need the boxes check, or they go missing.
Rick
After more expermentation I find that the problem occurs every time the computer goes to sleep.
If I reboot WI-Di works flawlessly.
As I mentioned previously, "Allow the computer to turn off power to this device" box is already unchecked.
Is this normal that one must reboot the computer to restore functionality once the computer entered nthe sleep mode and thereby enable the Intel Wi-Di function to operate?
Or is there a way to set it up so that Wi-Di will still operate after the pc has taken a nap (without a reboot)?
Jensor
