Wireless
8615 Discussions
ac9560 upgrade to ax200 or ax201?
bbaya2
good day everyone, i have core i7 8th gen , hm370 chipset, that has ac9560 wifi card.. which cards i can upgrade with ax200 or ax201? thnks
n_scott_pearson
The AC9560 card is a CNVio-based board and requires a special version of the M.2 Type E socket to host it. The AX201 card is a CNVio2-based board and requires a different special version of the M.2 Type E Socket to host it. The AX200 card provides a standalone WiFi solution and any M.2 Type E socket should be able to host it -- in theory. In order to determine whether it will work in your motherboard, you will need to contact your motherboard manufacturer and ask them this question.
Hope this helps,
