I'm trying to get Linux versions of ANT and DRTU tools to support FCC required testing of our device. I know Intel will instruct me to speak with my FAE, but my experience is that Intel will not assign an FAE to a company who purchased modules through distribution (Mouser).
Is there another path to acquire these tools?
Hello, @jdema
To get these tools, you need to contact your Intel FAE or Intel representative, you can contact an Intel FAE through the Intel Authorized Distributors, if you don't have one, you can ask one of them.
Jocelyn M.
“ANT tool, Version 22.2000.0.0-05160 (C) 2007-2020 Intel corporation” is outdated, so unfortunately hardware ;
The parameters in the Ant.exe and HwDetection.xml files say “Detected hardware: Intel(R) Wi-Fi 7 BE200 320MHz". cannot be found.
With parameter information for the Intel(R) Wi-Fi 7 BE200 320MHz network adapter;
I cannot find Intel's new “ANT tool” version for 2023 or 2024. help please.
windows 11, 24H2, Intel Wireless WiFi 23.60.0.10
In the tests performed ;
“C:\ANT>ANT.exe --QueryMCC
(C) 2007-2020 Intel company / OEM Tools group. All rights reserved.
Detected hardware: (???? ---none.)
or any network adapter defined as crf_id=“0x0f” in the HwDetection.xml file;
for example:<Device name=“TYPHOON” crf_id=“0x0f” rf_type=“0x010D” />
C:\ANT>ANT.exe -QueryMCC
Error: The read command fails with the following condition: , 256 (error.
In short, for Intel(R) Wi-Fi 7 BE200 320MHz, with the following or Intel's “ANT Tool 2023 or 2024” actual information
<Device name=“GALE2” should contain crf_id=“0x0f” rf_type=“ 0x0F08” but this parameter
“Ant tool” that contains these parameters. please.
best regards
“Nart”
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
