Wireless
8657 토론
ax200 speed drop on Ax router
abogrhen
초보자
12,249 조회수
i have been using ax200 for a while now
but when i connect it to an AX router
the speed is great But after few hours the speed goes down significantly
the only solution is to disable the wifi card and enable it again which solve it for a short period of time
win10 on 21.30.3
0 포인트
15 응답
Wanner_G_Intel
중재자
10,204 조회수
Hello abogrhen,
Based on the information provided on the following thread, https://forums.intel.com/s/question/0D50P00004QdHEF, we would like to know if you are still experiencing this problem under this system configuration:
MAXIMUS VII HERO - https://www.asus.com/Motherboards/MAXIMUS_VII_HERO/specifications/
Intel® Wi-Fi 6 AX200 21.30.3
Microsoft Windows 10 Pro Insider Preview 10.0.18965 Build 18965
BIOS 3003, 10-28-2015 (Not the latest) - https://www.asus.com/Motherboards/MAXIMUS_VII_HERO/HelpDesk_Download/
Note: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Also, we would like to have the following information:
1. Did the Intel® Wi-Fi 6 AX200 come preinstalled on your motherboard? Is this a wireless integration?
2. What is your router model?
Wanner G.
A Contingent Worker at Intel
0 포인트
abogrhen
초보자
10,204 조회수
using the same system but i went back to stock win10 to see if the insider is the problem
the wifi card is installed by me
i had INTEL WIRELESS-AC 9260 and before that AC 7260
with no problem
i tried a clean install of windows but the same problem
the router is netgear rax120 ax6000
0 포인트
Wanner_G_Intel
중재자
10,204 조회수
Hello abogrhen,
Thank you for your response.
When performing a clean installation of the wireless drivers, we recommend using these steps:
Clean Installation of Wireless Drivers
It is recommended to perform a clean installation of both the Wi-Fi and Bluetooth drivers.
Intel® Wireless Bluetooth® version: 21.30.0
Windows® 10 Wi-Fi Drivers version: 21.30.3
Please let us know if the issue persists if you follow these steps.
Wanner G.
abogrhen
초보자
10,204 조회수
so after more troubleshooting by me
and getting my hand on
7 laptops and 4 AX routers
5 laptops uses the ax200 the other 2 uses other cards
2 routers are the same netgear rax120 the other 2 are asus and d-link
all the 7 laptops don't have problem with other 2 router( ASUS and D-LINK )
the 2 laptops with non intel card don't have problem with netgear
the 5 laptops with intel cards have the same problem as my pc as they connect at full speed but after some time the speed drops significantly
0 포인트
abogrhen
초보자
10,204 조회수
so as i expected it is SW compatibility problem between the intel AX200 and the RAX120
i hope intel and netgear work it out
CGood12
초급자
10,204 조회수
Just like to say the Clean Install instructions vastly improved my speeds. Now I'm getting 500 down / 600 up on an Asus AX11000
0 포인트
AlHill
수퍼 사용자
10,204 조회수
No one will see your post in the middle of a five month old thread.
Doc
0 포인트
CGood12
초급자
10,204 조회수
You did. And I saw & was assisted by the information in a 5 month old thread.
0 포인트
Wanner_G_Intel
중재자
10,204 조회수
Hello abogrhen,
We would like to gather more information based on your findings.
1. 5 laptops with Intel® Wi-Fi 6 AX200.
Did they come with the Intel® Wi-Fi 6 AX200 preinstalled? Did you perform a hardware integration on these systems?
2. Make sure both the laptops and the RAX120 routers are using the the same Wi-Fi standard and configuration.
  • Right-click Start in the bottom left corner.
  • Click Device Manager.
  • Click the > sign to expand the Network adapters entry.
  • Right-click the wireless adapter and click Properties.
  • Click the Advanced tab to configure the advanced settings.
  • Make sure the 802.11n/ac/ax Wireless Mode or HT Mode is set to 802.11ax to enable 802.11ax data rates.
  • Check this configuration on the router, too.
3. If the issue persists, try using the VHT mode or 802.11ac standard on both the laptop and the router for testing purposes.
Wanner G.
0 포인트
abogrhen
초보자
10,204 조회수
for the 5 laptops the ax200 was preinstalled
the configuration was as you mentioned
i tried to set to AC only mode but still happened
also today
i tried on one laptop the killer newer driver to test (21.40.2.2)
the speed drop still happen but less frequently than before in 10 hours one time
so i think it is SW compatibility problem between the two
also if you continuously uploading or downloading the problem disappear
as soon as the connection idle for some time the speed drop
0 포인트
Wanner_G_Intel
중재자
10,204 조회수
Hello abogrhen,
We will do further research about this behavior and update this thread soon.
Wanner G.
0 포인트
Wanner_G_Intel
중재자
10,204 조회수
Hello abogrhen,
Since the 5 laptops came with the Intel® Wi-Fi 6 AX200 preinstalled, we would like to know if this problem happens while using the Original Equipment Manufacturer (OEM) drivers or the generic drivers available at the Download Center. Having speed issues or any other behavior in more than 5 systems usually means that there is a driver, OS, or compatibility issue.
If this problem occurs while running both OEM and generic drivers, then there could be an issue with the integration performed by the system manufacturer in these computers. These systems may need to have a specific setting (BIOS, OS, etc.) configured in order to alleviate it.
For these reasons, our recommendation is that you can contact your Original Equipment Manufacturer (OEM) and report this problem so that they can try to reproduce it or contact the router manufacturer or Intel if needed.
Wanner G.
0 포인트
abogrhen
초보자
10,204 조회수
OEM and generic drivers are used for all and from different manufacturer ( Razer-dell-lenovo )
they are coworker laptops that i asked for to test and all of them don't have an AX router so they did not notice the problem
the problem happened first on a desktop pc where I have upgraded the wifi card to the ax200 so i don't think it is "issue with the integration performed by the system manufacturer in these computers "
i have contacted netgear and there is multiple people in there forum facing the same problem with ax200 when used with RAX120
0 포인트
kchan160
초급자
10,204 조회수
I got the same problem from Intel AX200 with Netgear RAX120. The speed drop is terrible.
I am regret why don't I search this post before buying.
Wanner_G_Intel
중재자
10,204 조회수
Hello abogrhen,
Performing wireless integrations is subject to country-specific legal regulations. Before installing or changing the Intel® Wireless Adapter, Intel recommends that you contact the system manufacturer to obtain approval, step-by-step instructions, and support. It is worth mentioning that the integration may or may not work. It may also cause other performance issues due to the following reasons:
1. Hardware/software compatibility issues or dependencies.
2. Manufacturer limitations.
3. Driver limitations.
We definitely understand the points you have made on this thread, but we recommend you to work with the Original Equipment Manufacturer (OEM) first to determine if they can reproduce this issue and try to contact the router manufacturer.
It is worth mentioning that this problem could be related to your environment and network configuration.
Wanner G.
0 포인트
응답
