Wireless
8506 Discussions
ax200 usb disconnected after some seconds wifi crash
jay_chen1986
Hi all
The WIFI 6 AX200 crash in my PDA
ubuntu 20.04
kernel 5.15.71
cpu nxp imx8mm
ACarmona_Intel
Hello jay_chen1986,
Please generate an SSU report to help me further analyze your system specifications and configurations. To generate the SSU report, please refer to the article: Intel® System Support Utility for the Linux* Operating System. Please send us the generated SSU.txt file.
Carmona A.
ACarmona_Intel
Hello jay_chen1986,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
jay_chen1986
ACarmona_Intel
Hello jay_chen1986,
Thank you for the response.
In order for me to provide you the appropriate recommendation in regard to the issue in our case, please provide the following information:
  • When did the issue start, and was the Wi-Fi 6 AX200 working fine before?
  • Do you remember if this issue happened after a new OS update or wireless driver update? If yes, have you tried a rollback to a previous driver version for testing?
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • Do you see any error code in Device Manager?
    • To check, please go to Device Manager > Network Adapters > double-click on Intel Wi-Fi 6 AX200 and check the error code and error description in the General tab. Then share the screenshot with me.
  • Lastly Please generate an SSU report to help me further analyze your system specifications and configurations. To generate the SSU report, please refer to the article: Intel® System Support Utility for the Linux* Operating System. Please send me the generated SSU.txt file.
Carmona A.
ACarmona_Intel
Hello jay_chen1986,
Thank you!
Carmona A.
ACarmona_Intel
Hello jay_chen1986,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Thank you.
Carmona A.
VonM_Intel
Hello jay_chen1986,
I have not heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
