Hello @john_
In order to review this further, please provide us with the following information:
1- What changes did occur at that moment of the issue? Was there any recent Windows* or driver update? Or was any hardware/software change? Please provide details.
2- Is the Intel® Wi-Fi 6 AX201 the original wireless adapter that came pre-installed on the system? Or did you integrate/replace it on the computer?
3- Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system:
- Download the Intel® SSU and save the application on your computer
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
- Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
1. Other than windows updates and intel driver updates (which are both automatic as far as i know) I have not changed anything recently.
2. The ax201 is the original driver the computer came with.
3. I have the .txt file but i only see a cancel button below post reply.
Hello john_
Thank you for your response.
Under the response textbox here in the thread, you should see at the bottom a legend reading "Drag and drop here or browse files to attach".
The word "browse" is also a button to open a window explorer pop-up to search and attach files. Once you select and upload the Intel® SSU report (.txt file), you will see a thumbnail of the file. Once you are ready to post your reply, you just need to click on the blue button "Post Reply" and this should attach the file to your reply.
Also, when you said that "Intel drivers are automatic". Are they automatically installed via the Windows* Update Service, or are you using any particular tool to automatically update the drivers?
Please let us know if you have any other inquiries.
Andrew G.
Hello john_
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
Hello john_
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
