Wireless
8554 Discussions
bluetooth error on Debian 11
potterbl
When i turn on bluetooth in blueman it turns on and hides in few seconds and there are some errors.
Below will be my tests for quick answer.
Снимок экрана_2023-12-16_04-30-22.pngСнимок экрана_2023-12-16_04-32-13.pngСнимок экрана_2023-12-16_04-32-54.pngСнимок экрана_2023-12-16_04-33-38.pngСнимок экрана_2023-12-16_04-34-19.pngСнимок экрана_2023-12-16_04-35-10.png
potterbl
also
potterbl
potter@potter:~$ sudo dmesg | grep -i bluetooth
[ 5.115580] Bluetooth: Core ver 2.22
[ 5.115606] NET: Registered PF_BLUETOOTH protocol family
[ 5.115607] Bluetooth: HCI device and connection manager initialized
[ 5.115610] Bluetooth: HCI socket layer initialized
[ 5.115612] Bluetooth: L2CAP socket layer initialized
[ 5.115614] Bluetooth: SCO socket layer initialized
[ 5.267143] Bluetooth: hci0: Device revision is 2
[ 5.267156] Bluetooth: hci0: Secure boot is enabled
[ 5.267159] Bluetooth: hci0: OTP lock is enabled
[ 5.267161] Bluetooth: hci0: API lock is enabled
[ 5.267163] Bluetooth: hci0: Debug lock is disabled
[ 5.267164] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 5.267168] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 5.267552] bluetooth hci0: firmware: failed to load intel/ibt-0040-2120.sfi (-2)
[ 5.267710] bluetooth hci0: firmware: failed to load intel/ibt-0040-2120.sfi (-2)
[ 5.267760] Bluetooth: hci0: Failed to load Intel firmware file intel/ibt-0040-2120.sfi (-2)
[ 6.216609] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.216611] Bluetooth: BNEP filters: protocol multicast
[ 6.216614] Bluetooth: BNEP socket layer initialized
[ 2200.844127] Bluetooth: hci0: Device revision is 2
[ 2200.844130] Bluetooth: hci0: Secure boot is enabled
[ 2200.844131] Bluetooth: hci0: OTP lock is enabled
[ 2200.844131] Bluetooth: hci0: API lock is enabled
[ 2200.844132] Bluetooth: hci0: Debug lock is disabled
[ 2200.844132] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 2200.844133] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[ 2200.844144] bluetooth hci0: firmware: failed to load intel/ibt-0040-2120.sfi (-2)
[ 2200.844150] bluetooth hci0: firmware: failed to load intel/ibt-0040-2120.sfi (-2)
[ 2200.844151] Bluetooth: hci0: Failed to load Intel firmware file intel/ibt-0040-2120.sfi (-2)
Jose_Intel
Hello @potterbl
Thank you for posting on the Intel️® communities.
We understand you are experiencing connectivity issues with the Bluetooth, we will be more than happy to assist you.
Please answer the following:
·      What is the exact model of your network adapter?
·      Was it working before?
·      What is the kernel version?
Jose B.
Intel Customer Support Technicianv
Jose_Intel
Hello potterbl
We hope you are doing fine.
Were you able to check the previous questions?
Jose B.
IsaacQ_Intel
Hello potterbl,
Best regards.
Isaac Q.
