Wireless
8511 Diskussionen
can't install wifi driver error code 1603
Brinisamahra
Einsteiger
1.021Aufrufe
i can't install the intel wifi driver and there is not wifi button.
2 Antworten
n_scott_pearson
Superuser
966Aufrufe
What wireless module do you have and what version of the driver package were you attempting to install?
If you are unable to ascertain what this information is, please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
jerrymh
Einsteiger
693Aufrufe
Here's the result of my scan for the error code 1603 trying to install wifi drivers...
Antworten
