Wireless
8782 Discussions
carte réseau Intel(R) Wi-Fi 6 AX201 160MHz code 10 or 43
Dy-Reverse
Hello, I have been experiencing a problem with my network card with code 10 or 43 for a few days.
I have no access to wifi on my computer, no more wifi icon or connection.
I have a problem with the Intel(R) AX201 160MHz which loses its connection.
The warning remains on the driver despite the installations and uninstallations of updates and reboots.
I even installed Intel driver and assistant but it tells me that everything is up to date.
No new updates with Windows Update so I don't know what this is due to.
2 times out of sleep mode and 1 time on power up.
This time do not know how to solve this problem.
Thanks for your help
Jean_Intel
Hello Dy-Reverse,
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • Does the network connection work as expected on other systems?
  • Is this a laptop or desktop system? What is the model of your system?
Perform a Clean Installation of Wireless Drivers. Clean installation of the wireless/Bluetooth drivers is a troubleshooting step recommended to remove any previous installation files that might cause conflicts with new driver installations. There are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, Intel’s generic graphics drivers are intended for testing, and our latest driver is the 22.170 version.
Jean O.
Jean_Intel
Hello Dy-Reverse,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello Dy-Reverse,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
Jean_Intel
Hello Dy-Reverse,
As my last recommendation, I would recommend you check this article that contains information about the issue you mentioned. However, if the article suggestions do not solve the issue, I recommend you contacting with your Original Equipment Manufacturer (OEM).
Remember that, as I mentioned before, I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
