Wireless
8875 Discussions
description for Event ID 6062 from source Netwtw12 cannot be found (Intel Wi-Fi 6E AX211 160 MHz)
Sunity
I have the same issue as those 2 topics :
https://community.intel.com/t5/Wireless/description-for-Event-ID-6062-from-source-Netwtw12-cannot-be/m-p/1451766#M45178
https://community.intel.com/t5/Wireless/Windows-11-Event-Viewer-The-description-for-Event-ID-6062-from/m-p/1414014
I didn't find any correction, so i come back to you.
I also have the issue with the I226-V which is not resolved yet.
This issue can be link to the I226-V one ?
I link my SSU.
Thank you
Jean_Intel
Hello Sunity,
I understand you are having issues error message stating Event ID 6062 from source Netwtw12 cannot be found.
However, you first mentioned your wireless adapter (Intel Wi-Fi 6E AX211 160 MHz), and at the end of the post, you said that the issue is present with your ethernet adapter. I would like to confirm if the issue is present when using a Wi-Fi connection, or if it also occurs when you use a LAN connection.
Jean O.
Jean_Intel
Hello Sunity,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello Sunity,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
