I tryed to install drivers Inter(R) Wireles Bluetooth V.17.1.1450 for USB\VID_8087&PID_0A2A&REV_0001 (id Bluetooth). And when i install default drivers (notebook drivers), i see how change text in "Equipment Manager" from "Unknown device" to "Bluetooth", on 5 sec, and then again change to "Unknown device". Then I try Intel(R) Driver Update Utility, result: when i try manual install drivers from "Installed drivers" i have error "INF file was writed for windows 95". What i must do for installing this driver for bluetooth. Thanks.
- Tags:
- Drivers
- USB General
mixtech911,
What Intel® Wireless Adapter and OS you have installed in your computer?
Is this wireless adapter the original one installed by factory?
Inlet(R) Wireless-N 7265 - id : PCI\VEN_8086&DEV_095A&SUBSYS_50028086&REV_61
OS : Win7 x64
Adapter is original. I think problems in my actions.
Now i see this:
Driver installed, but bluetooth - unknown device.
Status device: Нужно заново установить драйверы этого устройства. (Код 18) / Need to install drivers for this device (Cod: 18).
mixtech911,
According to Microsoft*, Code 18 error indicates that the drivers need to be updated or uninstalled and reinstalled as shown decribed here: https://support.microsoft.com/en-us/kb/310123 Error codes in Device Manager in Windows
If necessay clean uninstall the drivers and install them again from your OEM. If you notice that the issue still persists, you may try the following:
1. Download and save: https://downloadcenter.intel.com/download/25319/Intel-PROSet-Wireless-Software-for-Bluetooth-technology-for-Windows-7-64-bit Download Intel® PROSet/Wireless Software for Bluetooth® technology for Windows 7* 64-bit
2. Proceed to uninstalling the Bluetooth* drivers to the point that the system will see it as an unknown device.
3. Proceed with the installation.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
