Wireless
9037 Discussions
intel 7260 ac issues
АСапр
Hello, at windows 8.1(i've reinstall it 3-5 times) with all updates i can't force to work that card
i've tried install drivers in device manager by updating through internet
by installing different version of drivers
it's showing network only at microsoft driver but after trying to connect some network( 802.11n) device manager starts refresh list.. i think card reseting after connect
and not showing connections until not manual update drivers to intel and back to microsoft .. or launcching troubleshooter (it's resseting driver settings or something like that)
then i've tried to install windows 10 technical preview update drivers through device manager(from internet) and mirracle happends it WORKS .. even i've installed last proset driver and programm
but again trouble IT'S VERY SLOW WORKING internet/lan dosen't matter it's realy not up faster 1.5mb/sec
i've (300mb/sec tplink tl1043wrd(v1) router) and my network provider presens me 5mb/sec internet acces
what i've should do with windows 8.1(to make 7260 works) or with windows 10 tech preview (to make 7260 working faster) ?
at ubuntu 14.10 it up's from first run but it slow too and through time it slows to 0
mayby and with ubuntu somone help but it's not on first priority
Kevin_M_Intel
Hi 0crash0,
There are some steps you can take as part of the troubleshooting steps:
  1. Reduce the environment noise as much as possible.
  2. Change the router security encryption. Refer to the following link:
http://www.intel.com/support/wireless/wlan/4965agn/sb/cs-025643.htm http://www.intel.com/support/wireless/wlan/4965agn/sb/cs-025643.htm
  1. Disable uAPSD. Check this link:
http://www.intel.com/support/wireless/wlan/sb/CS-034875.htm http://www.intel.com/support/wireless/wlan/sb/CS-034875.htm
  1. Try using the 5MHz Band by changing the router to 5GHz Band.
  2. Check this link with more troubleshooting steps:
http://www.intel.com/support/wireless/wlan/4965agn/sb/CS-028449.htm http://www.intel.com/support/wireless/wlan/4965agn/sb/CS-028449.htm
Kevin M
АСапр
Hi Kevin M,
router broadcast 11n only 40mhz width wpa2 personal with aes encription
i've not seen uAPSD feature in driver settings
Ad Hoc QoS Mode = WMM Disabled, but WMM enabled on router
ok that all settings:
802.11n channel width (band 2.4/band 5.2) = Auto
Ad hoc channel 802.11 b/g = 1
Ad hoc QoS mode = WMM Disabled
ARP offloading for WOWLAN = Enabled
Bluetooth® AMP = Enabled
Fat channel intolerant = Disabled
GTK rekeying for WOWLAN = Enabled
HT mode = VHT Mode
Mixed mode protection = CTS-to-self Enabled
NS offloading for WOWLAN = Enabled
Packet Coalescing = Enabled
Preferred band = No preference
Roaming aggressiveness = Medium
Sleep on WOWLAN disconnect = Disabled
Transmit power = Highest</stro...
