Wireless
8667 Discussions
Dual Band Wireless-N 7260 High Ping Problem
MAltu1
Hi bought a laptop Dell insprino 7537 models.
rise in online games, but I'm having instant ping
Ping values, 40 - 90 of 300 -900 while she is getting.
In the following video you can better understand.
This problem exists in everyone who uses the Dell 7537 high ping problem exists only in online games
https://www.youtube.com/watch?v=q6zM492-6Jo Wireless N 7260 Online Game ping Problem - YouTube
tvete
Valued Contributor II
Can you post a ping test of your router 360 times?
To do this just run cmd.exe and type (no quotes) "ping (your router's gateway) -n 360" and enter key. A normal ping should look something like below. Mine is also a Dual Band Wireless-N 7260 with Dell's 16.8.0.6 drivers:
Pinging 192.168.1.101 with 32 bytes of data:
Reply from 192.168.1.101: bytes=32 time=2ms TTL=64
Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time=1ms TTL=64
Reply from 192.168.1.101: bytes=32 time=7ms TTL=64
Reply from 192.168.1.101: bytes=32 time=9ms TTL=64
Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time=9ms TTL=64
Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time=1ms TTL=64
Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time=1ms TTL=64
Reply from 192.168.1.101: bytes=32 time<1ms TTL=64<p> Reply from 192.168.1.101: bytes=32 time=10ms TTL=64
Reply fro...
MAltu1
I'll be able to copy it
Driver version 16.5.3.6
Reply from 192.168.1.1: bytes=32 time=2ms TTL=30
Reply from 192.168.1.1: bytes=32 time=9ms TTL=30
Reply from 192.168.1.1: bytes=32 time=5ms TTL=30
Reply from 192.168.1.1: bytes=32 time=12ms TTL=30
Reply from 192.168.1.1: bytes=32 time=3ms TTL=30
Reply from 192.168.1.1: bytes=32 time=4ms TTL=30
Reply from 192.168.1.1: bytes=32 time=25ms TTL=30
Reply from 192.168.1.1: bytes=32 time=6ms TTL=30
Reply from 192.168.1.1: bytes=32 time=8ms TTL=30
Reply from 192.168.1.1: bytes=32 time=28ms TTL=30
Reply from 192.168.1.1: bytes=32 time=32ms TTL=30
Reply from 192.168.1.1: bytes=32 time=2m...
tvete
That's what is causing your lag. That ping spikes would literally kick you out of the server. A consistent ping of 1 - 20 ms to the router is needed for lag free connection. It might be something to do with WiFi interference. Since you have a 5 GHz capability with your laptop, I highly recommend for you to use it instead of connecting to 2.4 GHz since there are a lot of noises that interferes with that frequency. If you live in USA, a cheap $ 25 Netgear Refurbished WNDR3400v1 router on Amazon is all you need (this is my secondary router/AP by the way and it's only broadcasting 5 GHz). You can set that refurb router as an AP so that you can still use your primary router. My primary router is Netgear WNR2000v2 since I have other devices that need the 2.4 GHz band. I stream media through WiFi a lot so I needed minimum RF noise which the 5 GHz band deliver.
BTW, if you're interested with the 16.8.0.6 drivers, you can download it from the Dell site here: http://www.dell.com/support/drivers/us/en/22/DriverDetails?driverId=HRMXV Driver Details | Dell US
MAltu1
I update the driver but still the problem continues.
I use it as a modem to Asus n12.
In connection protocol B + G+ N 2.4 GHz
Dell 7537 with everyone have this problem area.
Correction of this problem, we have the opportunity to take the 5 GHz modems yet?
tvete
It sounds like the modem that you use (I assume it's the ISP issued modem) has a built-in WiFi. If that's the case, you can leave that modem alone and purchase a DUAL BAND router (dual band guarantees that it has 5 ghz radio) which you set up as an AP or you can buy a "true" AP (eg. Ubiquity UniFi PRO which is expensive BTW). I happen to live in very WiFi infested apartment where all of my devices not just my laptop suffer random ping spikes due to WiFi interference. Like I wrote previously, 5 GHz radio is the solution since it eliminates most of radio interference and it has way more channels available. The disadvantage is just the range is 1/2 of the 2.4 GHz range.
MAltu1
I wonder if a little expensive solution you just said it follows up usb wifi adapter to solving my problem?
http://www.amazon.com/gp/aw/s/ref=is_box_?k=usb+wifi http://www.amazon.com/gp/aw/s/ref=is_box_?k=usb+wifi
tvete
If the USB WiFi doesn't have massive ping spikes at 2.4 GHz, the drivers or the 7260 might be at fault. I suggest for you to test it out and see.
MHann7
Theveterans is right. The 5 Ghz band is great to reduce radio interference. And a good router makes a big difference. I get good range on the 5 Ghz band and my 2.4 Ghz band performs better after I bought a Netgear N900 Dual Band Gigabit Router (WNDR4500). I replaced another brand of router, whose name I shall not mention. The difference was like night and day. I saw the Amazon reviews before I bought the router and other people were also having good luck with this router. It's not a fix for every wireless issue, but a good router or access point does make a big difference.
AKule1
GUYS I SOLVED THE PROBLEM
however, you will not like the solution.
i tried all the drivers from the different threads and the problem still persists. I assume that Intel has a technical design flaw in the card which they are not willing to admit (otherwise the company will go bankrupt).
So, the only solution is to switch to another card. As someone suggested in another thread, I chose Broadcom 94352 (Broadcom 4352), otherwise known as Azurewave AW-CE123H.
It has all the same functions (b/g/n/ac, bt4.0) and works flawlessly.
7260 is unfixable, unreliable crap. Same as 6235.
Intel can go **** itself.
tvete
Glad the Broadcom works for you. One thing to note though is that Broadcom disables roaming when streaming (wmm). Intel 7260 doesn't do this automatically on some configurations but Intel 7260 on my laptop behaves the way broadcom cards work.
