My WIFI driver (Intel(R) Wi-Fi 6 AX201 160 MHz) has stopped functioning. I've tried running the Driver Assistant tool multiple times, and installing the newest version of the driver has not helped at all.
Intel(R) Wi-Fi 6 AX201 160MHz: Has been determined that the network adapter is not functioning properly. from Windows event
Some relevant info: I have an Asus RAG laptop on Windows 11.
and I send the result as attached
連結已複製
Hello diptw,
I understand your system is currently experiencing Error code 43 on your device manager, no worries, I will help you the best I can to resolve the issue with your Intel(R) Wi-Fi 6 AX201 160 MHz adapter.
Error Code 43 in Windows Device Manager typically indicates that the device has stopped because it reported problems. This can be due to various reasons, including driver issues, hardware malfunctions, or conflicts with other system components.
You may follow the troubleshooting steps below and see if it would help.
Check for Windows Updates: Ensure that your Windows 11 is up to date. Sometimes, system updates can resolve compatibility issues with drivers.
Reinstall the Driver:
- Get the latest graphics driver provided by the system manufacturer (ASUS).
- Uninstall the current driver from Device Manager.
- Restart your laptop.
- Install the drivers from ASUS
Check for Hardware Conflicts:
- Open Device Manager and look for any other devices with warning symbols.
- Resolve any conflicts by updating or disabling conflicting devices.
BIOS Update: Check if there is a BIOS update available for your ASUS ROG laptop. Sometimes, updating the BIOS can resolve hardware compatibility issues.
Reset Network Settings:
- Go to Settings > Network & Internet > Status.
- Click on "Network reset" to reset all network adapters to their default settings.
For more information regarding the troubleshooting above, you may also refer to the article Codes 10, 22, 28, 31, 43 or 45 Errors in Device Manager for Bluetooth® or Wireless (Wi-Fi) Devices
Just in case the issue persists after the steps above, please share with me the following:
- When did it start to happen?
- Have tried a roll back to a previous driver version for testing?
Along with that, kindly provide a scan of Intel® System Support Utility for Windows* as well so that I may review your system specifications.
Sean Lemuel D.
Hello diptw,
Just checking in to see if you have had the chance to look over my recommendations and information I asked. Let me know when you can so we can figure out the best way to move forward.
Sean Lemuel D.
Hello diptw,
Sean Lemuel D.
Hello diptw,
To add to my previous post, I also recommend contacting ASUS as you have already tried several troubleshooting steps to resolve the issue based on your original post.
Sean Lemuel D.
