Wireless
8617 Discussions
intel wi-fi 6 ax200 160mhz connection problems
Sebastian26
Hello.
I come back with the same problem from last time. (Link from the last topic https://community.intel.com/t5/Wireless/wifi-connection-problem/m-p/1252134/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtLTjZSSlpQQVhPUVJCfDEyNTIxMzR8U1VCU0NSSVBUSU9OU3xoSw#M33786 ) The solution took me a while (about 1 month) but after that it started to persist exactly the same. My wifi disconnects randomly once every 1 minute / 5 minutes or 10 maximum.
I tried last version of drivers but nothing.
Is there another solution that can help me? Or what other cause can this discomfort create?
Every time I let Windows fix this problem, it gives me "problem with network adapter or access point - solved" but apparently it's still not solved.
Please help!!!
David_G_Intel
Hello Sebastian26
Thank you for posting on the Intel️® communities.
 As recommended on the previous thread, the best course of action in this case is to test the same steps as before. If the issue persists contact the OEM for additional troubleshooting, or a different solution.
David G
Intel Customer Support Technician
