Wireless
8521 Discussions
my ax200 is not stable and don't work correctly
Narashi
Débutant
867 Visites
Hey everyone,
my intel ax200 isn't stable, I mean, it keep disconnecting et dispear from peripheral manager and reconnect sometime.
when I use to much my internet ( open multiple tabs) it disconnect.
I can disable the ax200 and somtime it work for 2 3 minute and disconnect, it do the same for uninstalling the ax200.
I tried everything (uninstalling drivers and reinstalling with windows, updating the drivers, using older drivers...)
I have this problem since 9 month. I have a laptop: Acer Swift SF114-33
(I am french so sorry for my bad english...)
0 Compliments
3 Réponses
Steven_Intel
Modérateur
825 Visites
Hello Narashi,
I am sorry you are having issues with your Intel® Wi-Fi 6 AX200, I will be glad to help you.
Please provide the following information:
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • Was the wireless adapter working fine before? If so, was there any hardware change or driver/OS update that may have triggered the issue?
  • Do you see any error code in Device Manager > Network adapters > Double-click on Intel® Wi-Fi 6 AX200 ? It should appear along with a yellow symbol.
  • Are you also having issues with Bluetooth connectivity?
Steven G.
0 Compliments
Steven_Intel
Modérateur
803 Visites
We would like to know if you were you able to check the previous post.
Steven G.
0 Compliments
Steven_Intel
Modérateur
778 Visites
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
0 Compliments
Répondre
