Wireless
Объявления
8567 Обсуждение
strange behavior with Killer(R) Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter (201NGW)
1650ikillerError
Начинающий
6 582Просмотр.
the speed is fast about 300 mbps about 1 to 15 minutes then suddenly jump down to 24 mbps , if i restart the wifi the speed jump back to 300mbps again, i tested with another usb wifi like tp link totolink and edup was working flawlessly with those usb wifi, only 201ngw have this problem, why is that?
i reinstalled windows, update drivers from acer website, frome intel driver and support
here is my specs
thanks for advance
0 баллов
18 Ответы
Mike_Intel
Модератор
6 499Просмотр.
Hello 1650ikillerError,
  1. What is the brand and model of your system?
  2. Was it working fine before?
  3. What was the last changes made before the issue started?
  4. Did you manually install this Intel AX1650 on your system or this is embedded on your system?
  5. What are the troubleshooting steps that you tried so far?
Michael L.
1650ikillerError
Начинающий
6 483Просмотр.
1. in the picture
2. i noticed it in end of 11/2024, i purchase this on 10/2024, maybe it have problem before but i dont notice
3. i installed some softwares, install lexar 2tb ssd, i reinstalled fresh windows and dont installed any software the problem still persist from the fresh windows installation
4. it come with my laptop, i dont manually install it
5. i only run dianose network problem but it said the wifi connect to the internet without problem
i read from reddit and internet and i found out that many people have this problem like me without a fix
Mike_Intel
Модератор
6 422Просмотр.
Thank you for the update.
Please help generate the SSU logs of your system. Kindly refer to the link below for the steps on how to generate the logs:
Michael L.
1650ikillerError
Начинающий
6 378Просмотр.
here is the file
Mike_Intel
Модератор
6 343Просмотр.
Can you try to perform clean driver installation of the driver? Please refer to the link below for the steps and the link of the latest driver.
https://www.intel.com/content/www/us/en/support/articles/000022173/wireless.html
https://www.intel.com/content/www/us/en/download/19779/intel-killer-performance-suite.html
Michael L.
1650ikillerError
Начинающий
6 326Просмотр.
thanks but this method doesnt work, it like intel wifi card error, because i search many people have the same problem, and like i wrote i tested with another mediatek card without problems
1650ikillerError
Начинающий
6 314Просмотр.
oh i found out there is new version 130 , i will report back if the error still happen or not
Mike_Intel
Модератор
6 266Просмотр.
Can you share the link of the latest version and kindly update us if installing this will improve your system.
Michael L.
Mike_Intel
Модератор
6 226Просмотр.
Michael L.
1650ikillerError
Начинающий
6 204Просмотр.
i get the error again, the speed suddenly move to slow speed, reset the wifi fast again, this is a hardware error, i resetted windows and use 3 difference drivers 60 and 120 and 130 and still get the error.
Mike_Intel
Модератор
6 065Просмотр.
By the way, what is the brand and model of the laptop and can you also share the link where did you get the version 130 driver?
Michael L.
Mike_Intel
Модератор
5 978Просмотр.
Regarding this issue, let me also ask/gather the following details:
  1. Do you have a background application that is using an internet connection?
  2. What is the engine prioritization of the Intel Killer Performance Suite? Ask for the screenshot.
  3. What frequency are they connected to? Is it 2.4, 5, or 6 Ghz?
  4. Is there any other device connected to the same network that has the same issue? Or is the issue only isolated to his laptop?
  5. Have you also tried using a different connection, such as a mobile hotspot or a different network?
Let me also add that we have a similar issue before, and this is what fixed the issue:
This is expected behavior. For example, Steam, or other app-launchers run as a Priority 4 by default, but the games, launched/ installed from Steam will have the default Priority 1. Priority settings can be manually changed in the Killer Control Center - Prioritization Engine section.
Michael L.
1650ikillerError
Начинающий
5 945Просмотр.
  1. Do you have a background background application that is using an internet connection? No
  2. What is the engine prioritization of the Intel Killer Performance Suite? Ask for the screenshot. i dont understand
  3. What frequency are they customer connected to? Is it 2.4, 5, or 6 Ghz? 5GHz
  4. Is there any other device connected to the same network that has the same issue? Or is the issue only isolated to his laptop? only 1650i, INSTALLED mediatek usb wifi the problem dont exist, another device like android phone work well, ONLY 1650I HAVE THIS PROBLEM,
  5. Have you also tried using a different connection, such as a mobile hotspot or a different network? yes and ONLY 1650i have this problem, this laptop install with another mediatek wifi dont have this problem, android phone dont have this problem, AMD laptop with mediatek wifi dont have this problem, and that is your fault to create a faulty card
1650ikillerError
Начинающий
5 945Просмотр.
I SAID again and again i dont see any problem with any usb wifi card or any devices i own, only this 1650i card, i replaced with mediatek card and install driver, no problems so far, yeah your wifi card products are faulty both 1550i and 1650i
Mike_Intel
Модератор
5 864Просмотр.
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Модератор
5 508Просмотр.
I sent an email in the email address indicated in your profile regarding this issue. Please check your inbox.
Michael L.
VonM_Intel
Модератор
4 958Просмотр.
I wanted to follow up regarding the email sent earlier by my colleague, Michael L., to the address on your profile. Please kindly check your inbox (and spam/junk folder, if necessary) to ensure you have received it. If you have any questions or require further assistance, please do not hesitate to reach out.
Von M.
BrianT_Intel
Модератор
4 516Просмотр.
Hi @1650ikillerError,
Brian T.
Ответить
