Wireless
7488 Discussions
ubuntu 20.04 Intel ax200 Failed to run INIT ucode: -110
MSD-Systems
Hello all,
i have an issue on a Fujitsu Board D3713-R2 with a AMD Ryzen Processor. The ax200 Module is populate on a adapter Board form m.2 to pcie.
The module is recognized on the pci.
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
               LnkSta: Speed 5GT/s (ok), Width x1 (ok)
The dmesg message shows a ADVANCED_SYSASSERT
[ 2481.077892] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 2481.077924] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[ 2481.077933] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 2481.077936] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 2481.078629] iwlwifi 0000:03:00.0: loaded firmware version 55.d9698065.0 cc-a0-56.ucode op_mode iwlmvm
[ 2481.078682] iwlwifi 0000:03:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 2481.099202] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 2482.124779] iwlwifi 0000:03:00.0: SecBoot CPU1 Status: 0x4, CPU2 Status: 0x1
[ 2482.124802] iwlwifi 0000:03:00.0: UMAC PC: 0xc00c0eb2
[ 2482.124818] iwlwifi 0000:03:00.0: LMAC PC: 0x0
[ 2482.124825] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired.
[ 2482.153867] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 2482.153876] iwlwifi 0000:03:00.0: Status: 0x00000000, count: -63936083
[ 2482.153881] iwlwifi 0000:03:00.0: Loaded firmware version: 55.d9698065.0 cc-a0-56.ucode
[ 2482.153887] iwlwifi 0000:03:00.0: 0xCB78D5F6 | ADVANCED_SYSASSERT
[ 2482.153891] iwlwifi 0000:03:00.0: 0x247BA027 | trm_hw_status0
[ 2482.153895] iwlwifi 0000:03:00.0: 0x5434B58F | trm_hw_status1
[ 2482.153899] iwlwifi 0000:03:00.0: 0xEF42C364 | branchlink2
[ 2482.153902] iwlwifi 0000:03:00.0: 0xD1D55FF2 | interruptlink1
[ 2482.153906] iwlwifi 0000:03:00.0: 0xA8D9B6EB | interruptlink2
[ 2482.153909] iwlwifi 0000:03:00.0: 0x118596CF | data1
[ 2482.153913] iwlwifi 0000:03:00.0: 0xA4DBF05B | data2
[ 2482.153916] iwlwifi 0000:03:00.0: 0x015A11FE | data3
[ 2482.153920] iwlwifi 0000:03:00.0: 0x5B197436 | beacon time
[ 2482.153923] iwlwifi 0000:03:00.0: 0x46BAF115 | tsf low
[ 2482.153926] iwlwifi 0000:03:00.0: 0x34BE2702 | tsf hi
[ 2482.153930] iwlwifi 0000:03:00.0: 0x8964617A | time gp1
[ 2482.153933] iwlwifi 0000:03:00.0: 0xE056FF48 | time gp2
[ 2482.153936] iwlwifi 0000:03:00.0: 0xC5451E56 | uCode revision type
[ 2482.153940] iwlwifi 0000:03:00.0: 0xD987B2A4 | uCode version major
[ 2482.153943] iwlwifi 0000:03:00.0: 0x81BC3C6E | uCode version minor
[ 2482.153946] iwlwifi 0000:03:00.0: 0xCBA8B9D3 | hw version
[ 2482.153950] iwlwifi 0000:03:00.0: 0xB61EDDB6 | board version
[ 2482.153953] iwlwifi 0000:03:00.0: 0x4D9749DB | hcmd
[ 2482.153956] iwlwifi 0000:03:00.0: 0xE2CC9BDA | isr0
[ 2482.153959] iwlwifi 0000:03:00.0: 0x5EACEAB7 | isr1
[ 2482.153963] iwlwifi 0000:03:00.0: 0x48F599E6 | isr2
[ 2482.153966] iwlwifi 0000:03:00.0: 0x97B6071F | isr3
[ 2482.153969] iwlwifi 0000:03:00.0: 0xE690E236 | isr4
[ 2482.153972] iwlwifi 0000:03:00.0: 0x1797CE16 | last cmd Id
[ 2482.153976] iwlwifi 0000:03:00.0: 0x690C9A6E | wait_event
[ 2482.153979] iwlwifi 0000:03:00.0: 0x1710BE22 | l2p_control
[ 2482.153982] iwlwifi 0000:03:00.0: 0x10A6216C | l2p_duration
[ 2482.153985] iwlwifi 0000:03:00.0: 0x9483C224 | l2p_mhvalid
[ 2482.153989] iwlwifi 0000:03:00.0: 0x42EAAF63 | l2p_addr_match
[ 2482.153992] iwlwifi 0000:03:00.0: 0x9118B7D7 | lmpm_pmg_sel
[ 2482.153995] iwlwifi 0000:03:00.0: 0x8931764D | timestamp
[ 2482.153998] iwlwifi 0000:03:00.0: 0x6F4E493D | flow_handler
[ 2482.154116] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 2482.154120] iwlwifi 0000:03:00.0: Status: 0x00000000, count: 7
[ 2482.154124] iwlwifi 0000:03:00.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 2482.154128] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
[ 2482.154131] iwlwifi 0000:03:00.0: 0x80465826 | umac branchlink2
[ 2482.154134] iwlwifi 0000:03:00.0: 0x00000000 | umac interruptlink1
[ 2482.154138] iwlwifi 0000:03:00.0: 0x804836C4 | umac interruptlink2
[ 2482.154141] iwlwifi 0000:03:00.0: 0x01000000 | umac data1
[ 2482.154144] iwlwifi 0000:03:00.0: 0x804836C4 | umac data2
[ 2482.154147] iwlwifi 0000:03:00.0: 0x00000000 | umac data3
[ 2482.154151] iwlwifi 0000:03:00.0: 0x00000037 | umac major
[ 2482.154154] iwlwifi 0000:03:00.0: 0xD9698065 | umac minor
[ 2482.154157] iwlwifi 0000:03:00.0: 0x000FDF8D | frame pointer
[ 2482.154160] iwlwifi 0000:03:00.0: 0xC0887F40 | stack pointer
[ 2482.154164] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
[ 2482.154167] iwlwifi 0000:03:00.0: 0x00000000 | isr status reg
[ 2482.154255] iwlwifi 0000:03:00.0: Fseq Registers:
[ 2482.154301] iwlwifi 0000:03:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 2482.154347] iwlwifi 0000:03:00.0: 0x80290021 | FSEQ_TOP_INIT_VERSION
[ 2482.154392] iwlwifi 0000:03:00.0: 0x00050008 | FSEQ_CNVIO_INIT_VERSION
[ 2482.154439] iwlwifi 0000:03:00.0: 0x0000A503 | FSEQ_OTP_VERSION
[ 2482.154484] iwlwifi 0000:03:00.0: 0x80000003 | FSEQ_TOP_CONTENT_VERSION
[ 2482.154530] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 2482.154576] iwlwifi 0000:03:00.0: 0x00100530 | FSEQ_CNVI_ID
[ 2482.154622] iwlwifi 0000:03:00.0: 0x00000532 | FSEQ_CNVR_ID
[ 2482.154668] iwlwifi 0000:03:00.0: 0x00100530 | CNVI_AUX_MISC_CHIP
[ 2482.154716] iwlwifi 0000:03:00.0: 0x00000532 | CNVR_AUX_MISC_CHIP
[ 2482.154765] iwlwifi 0000:03:00.0: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 2482.154812] iwlwifi 0000:03:00.0: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 2482.154860] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 2482.705479] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
kernel version is the 5.8.0-45-generic
Bluetooth is working
hcitool dev
Devices:
       hci0    F8:5E:A0:49:0C:04
many thanks for your support
MSD-Systems
Hello Deivid,
i do not really understand, why this should be an hardware issue, because the same hardware with the same wifi module works under windows.
best regards
MSD-Systems
Hello Deivid,
best regards
MSD-Systems
Hello Deivid,
do you have any updates for me ?
If I should discuss with the board manufacture i need more details regarding the error on the PCIe Bus.
thanks
Michael
