Wireless
7117 Discussions
when user connects to Sophos VPN client his laptop restarts automatically
govindpansare
when user connects to Sophos VPN his laptop restarts automatically and showing Blue screen with error "ndis.sys" Please help for solving this issue
Laptop Model :-HP ProBook 450 G5
Thanks in advance
govindpansare
Please check attached error system log file
Jean_Intel
Hello govindpansare
To have a better understanding of your issue, please provide me with the following:
  • When did the issue start?
  • Was there any hardware or software change before the issue started?
  • Does the BSOD appear when you are using wireless, ethernet connection, or both?
  • Is this the original card that came with the system?
Jean O.
govindpansare
Dear Team,
Kindly check below your questions answer in bold and revert ASAP
  • When did the issue start? ==> We realized this when we needed VPN last month
  • Was there any hardware or software change before the issue started? ==>No
  • Does the BSOD appear when you are using wireless, ethernet connection, or both?==>Both Ethernet and Wireless
  • Is this the original card that came with the system? ==>Yes
govindpansare
Dear Intel team,
Kindly check dumps file for your reference
govindpansare
Jean_Intel
Hello govindpansare,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello govindpansare
You mentioned that the issue also appears when using an ethernet connection. It seems as if the problem is not being caused by the wireless card; instead, it appears as if the VPN software is causing the BSOD. My suggestion is to try contacting the support for the VPN software and confirm if they have a newer version that solves the issue you are facing.
Jean O.
govindpansare
Dear Intel team,
The same issue came up when we  install open VPN and updated version of Sophos VPN, only 1 device having issue about VPN
Jean_Intel
As you mentioned that the issue doesn't appear until you run the VPN, I believe that the VPN software may be the root of the problem, so I suggested contacting the software developer. However, you can also try and contact HP to do a further hardware investigation and confirm if there is any problem with your system.
Jean O.
Jean_Intel
Hello tarhgovindpansare,
Jean O.
Jean_Intel
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
