Wireless
8878 Discussions
wireless update
lokkky
wireless disappeared after the update. I am currently connected to the Internet via an ethernet cable.
megan3000
Valued Contributor I
What update?
Driver update? OS update? BIOS update?
You should have provided more information so it is hard to help in this scenario... for instance, including the exact update that caused this... system or laptop model, OS version.. and so on...
Can you see an error on those devices (I see a yellow mark on them...)
Run this report, select Everything, change from summary to detailed view and save the file as a txt file, then upload it to your reply (don't use the option to submit/send the report, it doesn't work...)
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
