16676 Discussions
Error 10500 Help me !!!
so this is one of my first VHDL codes...
(havent finished the cnt select part on the bottom^^)
I get some "10500 vhdl Syntax error"s between 'begin' and 'with cnt select'... But why?? :(:confused:
I can't find anything missing ._.
library ieee;
use ieee.std_logic_1164all;
entity helloworld is
port(key0: IN STD_LOGIC;
Hex0: OUT STD_LOGIC_VECTOR(6 downto 0)
end helloworld;
architecture behaviour of helloworld is
signal a: STD_LOGIC;
signal cnt: STD_LOGIC := '0';
begin
a <= not key0;
if a = '1' then
cnt <= cnt + 1;
end if;
if cnt = '16' then
cnt <= '0';
end if;
with cnt select
end behaviour;
if statements must be in a procedural block of code - like a process
Also, it should be: use ieee.std_logic_1164.all;
@Tricky:
Oh thanks a lot , that must be the mistake^^ I didn't realize that as I'm more used to write in C.
I'll try again now :)
@sstrell:
Thank you but this mistake is only here in the Thread from typing.
